The analogue-summing '3D' effect: what actually is it?
Page 1 of 5
PostPosted: Sun May 24, 2020 11:51 am
by Dr Huge Longjohns
People who espouse the use of external analogue summing mixers often talk about the '3D' effect that these devices create. Somehow the individual instruments or sounds seem to have a space around them that's hard to describe but once you hear it, it's very attractive and hard to miss. Airwindows and other software manufacturers claim to be able to recreate this effect in the box with console emulations and so forth. Here's the Airwindows example which demonstrates it very well if you listen on monitors or phones:
https://www.youtube.com/watch?v=r8eSFNgSpuo
And this piece of software, DrMS, seems to achieve the same with a variety of processing, particularly phase shifting and cross-talk manipulation.
https://www.youtube.com/watch?v=u7TcIVLJN3o&t=677s
I have been able to achieve this effect in Logic Pro X simply by loading Waves Kramer Tape on the stereo bus but it's always hit and miss whether it works or not.
But what is the actual science behind this effect? It's certainly not "digital summing is broken" as some commentators would have us believe. What is going on to make this magical 'space' appear?
Re: The analogue-summing '3D' effect: what actually is it?
PostPosted: Sun May 24, 2020 12:17 pm
by desmond
If it's "magic", it can't be explained by science! :lol:
PostPosted: Sun May 24, 2020 12:18 pm
by Sam Inglis
I only skimmed through the Airwindows video, but I didn't hear anything magical. I heard mild saturation and a consequent added mid-range content, and small loudness variations. In fact in the very first example where he compared Console 4 to the raw digital mix I preferred the raw mix.
PostPosted: Sun May 24, 2020 3:47 pm
by DanielBeach
This may be a naive view, but isn’t it possibly just the side effect of each signal having gone through physical connections which can’t help but to add some noise/artefacts/whatever, and therefore colours the sound in some way, boosts some frequencies a little, etc?
PostPosted: Sun May 24, 2020 4:16 pm
by CS70
Think the common wisdom is that it's about crosstalk between channels. Tough that should _decrease_ separation, not increase it...
No idea however. I just mix it until it sounds good to me, problem solved :D
PostPosted: Sun May 24, 2020 4:20 pm
by MOF
I’ve bought the BX Focusrite Console plugin which has TMT in it to emulate the effect of using separate analogue channels, with their random slight variations of eq, phase shift etc, and to be honest if there is a change I can’t hear it so far on the few songs I’ve used it on but maybe you need to get to 24+ channels to hear it; there’s always a slight crossfade/delay when you switch off lots of plugins simultaneously to compare, so without doing several level compensated mixes and cutting between them it’s hard to judge, whatever is happening it’s subtle. Anyway I do like the sound of its eq, compressor etc and that’s the main reason I bought it.
I would say that trying out a Mid Side plugin and experimenting with the width and eq’ing the difference channel will give you more of that effect you want.
PostPosted: Sun May 24, 2020 4:24 pm
by CS70
One more thing, in Cakewalk you have ProChannel in every track which includes channel and bus emulations. They're supposed to emulate SSL, Neve and API consoles.
I do hear what they do quite clearly and I like it, so I use them quite extensively.
However, having never owned an SLL, Neve or API desk, I have no idea if they actually sound like them :D
PostPosted: Sun May 24, 2020 4:36 pm
At 2 mins in he switches it out. The mix suddenly sounds flat in comparison to me. Is this just the effect of losing the saturation?
PostPosted: Sun May 24, 2020 4:44 pm
Yes, I guess it's precisely this sort of thing, plus the cross-talk, phase anomalies etc. But I've never seen this '3d' effect explained properly in terms of what actually happens to the signals. Or as Sam says, it may be just our ears are getting fooled but simple saturation and volume changes.
PostPosted: Sun May 24, 2020 5:14 pm
by resistorman
MOF wrote:I’ve bought the BX Focusrite Console plugin which has TMT in it to emulate the effect of using separate analogue channels, with their random slight variations of eq, phase shift etc, and to be honest if there is a change I can’t hear it so far on the few songs I’ve used it on but maybe you need to get to 24+ channels to hear it; there’s always a slight crossfade/delay when you switch off lots of plugins simultaneously to compare, so without doing several level compensated mixes and cutting between them it’s hard to judge, whatever is happening it’s subtle. Anyway I do like the sound of its eq, compressor etc and that’s the main reason I bought it.
Same here, though I bought the SSL one for $49 when it was on sale. I use it on all my tracks now to start the mix off. And like cs70, never having owned an SSL, I don’t know how it compares, but it sounds great.
PostPosted: Sun May 24, 2020 6:42 pm
CS70 wrote:Think the common wisdom is that it's about crosstalk between channels. Tough that should _decrease_ separation, not increase it...
Not if the crosstalk signal has a lot of phase shift in some frequency regions and thus makes the image width wider rather than narrower.
And I suspect even-order harmonic distortions probably play a part too.
PostPosted: Sun May 24, 2020 6:44 pm
If you get a chance to listen to that Airwindows clip, Hugh, I'd love to hear your view on what's causing the sonic differences.
PostPosted: Sun May 24, 2020 7:24 pm
by CS70
MOF wrote:maybe you need to get to 24+ channels to hear it
It does certainly need to "sum up" a bit. Maybe not 24 channels, but the effect should be very subtle (after all, the original desks were built as usual to be as transparent as possible, or at least not with the current "let's emulate analogue" fixation) so it should get noticeable only with more than a handful of channels.
There's also the much more immediately noticeable "driving" of a channel's emulated preamp, which pops out right away with even a single channel (because you're distorting).
PostPosted: Sun May 24, 2020 7:26 pm
by CS70
Good point, hadn't thought of that.
PostPosted: Sun May 24, 2020 7:31 pm
by Martin Walker
JUMPING ONTO ONE OF MY FAVOURITE HOBBY HORSES ;)
Yes - this is exactly the hardware 'analogue summing' experience Chris has attempted to mimic, and is exactly what I hear too, having spent a long time working with his Console plug-ins.
Like you I could hear the switch from 'space round each individual sound' to flat, as heard in that mix (and I've since heard exactly the same differences between ITB and hardware analogue summing demos - once you lock onto how the sound is changing you can invariably hear it in future summing examples, whatever the gear involved).
However, at first I found the Airwindows Console benefits annoyingly elusive in my own mixes, and spent a long time exploring why, eventually writing up the findings on my web site:
http://www.yewtreemagic.co.uk/soundworlds7.php
The reasons I had difficulties? Chris' example of himself singing a single note around 20 times proved to be the perfect subject for revealing the difference, because:
a) Console 5 summing only became audible to me once there were at least a dozen tracks being mixed.
b) Console 5 provided vanishingly small audible summing improvements until the combined peak level of the tracks came close to 0dBFS, and since his singing was of a sustained note, he could optimise this drive level for maximum effect.
My initial demos were of more percussive music and around eight tracks, neither of which gave significant improvements, only occasionally being almost vanishingly audible under headphones, but as I explored more I began to get the idea, and finally began to reap the benefits, essentially by mixing together more channels with combined transient peaks around -2dBFS (going much higher ran into nasty distortion, so with Console 5 it proved to be a fine dividing line between maximum effect and overload).
I published my results, Chris himself was impressed by my efforts and confirmed all my findings, but just a couple of days later he released Console 6, essentially the same technique but using a different algorithm that kicked in at significantly lower audio levels, making it less necessary to push levels so close to 0dBFS to hear the improvements.
You can hear my audio demos via the link above - I offer the same short musical section three times; the first being standard ITB digital summing, the second using Console 5 carefully set to peak at -2dBFS, and the third being Console 6 with -6dBFS peaks.
Now to the audible differences (which I can still hear quite easily - see if you agree ;) )
The digital summing does sound flat, while Console 5 and Console 6 open this up - listen in particular to the voices in each version. To my ears the percussive voices sound more focused, giving the effect of being to discern each 'singer' more clearly, while the sustained voices sound significantly further away in the Console versions, giving the effect of more 3D 'depth'.
Finally, to the reasons for these changes. The Airwindows Console plug-ins add slight 'pre-distortion' to each channel via its Channel plug-in instances, and then the combined mixed signal is passed through a single Console Buss plug-in, which provides the reciprocal 'undistort' curve:
Now, with a few channels, the 'difference' signal is inaudible, but with a dozen or more channels peaking a few dBS below 0dBFS, some of the initial distortion applied to the peaks of the individual channels gets left in, mimicking the effect of a non-perfect mixing buss, where ambience gets pushed into the far distance. The actual sounds don't seem particularly altered, but the space between the sounds gets hammered with the full 'undistort' treatment, which sounds very distant and thin all by itself. This (to my ears anyway) gives slightly more 3D 'detail' to them i.e. more depth and a sense of enhanced "foreground", which is the effect commonly claimed for high-end analogue mixing desks.
Believe your ears or not as the case may be, but I can reliably hear the difference, and have been using Console 6 on every track I've written since exploring the possibilities.
