Metallic sound in vocal recording
Page 1 of 1
PostPosted: Thu Jul 02, 2020 11:59 pm
by Lever
Hi all.
I am in the process of recording some vocals for a project of mine and I am using an SM58. As soon as I push a little bit with the voice, I hear a strange metallic sound in my voice. I can remove some of it but not all if I cut around 9500Hz, but I think I really need to remove it at the source rather than afterwards.
The microphone is obviously dynamic and I sang about 20 cm (8 In) from it to ensure that I was not putting the capsule under stress. The gain on the soundcard (a Focusrite Scarlett 8i6) is pretty low and I'm miles away from clipping.
There was some reverberation in the room, so I sung facing a blanket in a closet also covering my head and shoulders with the same blanket. The noise is still there.
Does anybody have any idea what could be causing it? I am starting to think it may actually be my voice itself producing it somehow. Perhaps, I should ask if you hear it in the first place? I recorded 4 seconds where I think I can hear it pretty well. Here's a link to the file:
https://www.dropbox.com/s/f9uv00rt0ued4 ... d.wav?dl=0
Thanks!
Re: Metallic sound in vocal recording
PostPosted: Fri Jul 03, 2020 1:03 am
by MOF
I couldn’t hear anything metallic, you don’t need to be far away from the SM58, some singers almost swallow them, they are designed to be used close up and you’ll benefit from the proximity effect, which boosts the bass end.
What you’re probably hearing is a thin sound i.e. no bass and the upper mids sound nasally as a result.
PostPosted: Fri Jul 03, 2020 1:29 am
by Eddy Deegan
Not my area of expertise but for what it's worth I don't hear anything I would describe as 'metallic' either. I'm wondering if it's your familiarity with your own voice conflicting with the sound of it as picked up by a microphone.
Few, if any, people sound the same when recorded as they do to themselves when performing.
I've used SM58s on various occasions in the past in a live setting and to me the recording you linked sounds fairly typical of one, albeit possibly with the effects MOF mentions above.
PostPosted: Fri Jul 03, 2020 2:05 am
by Tim Gillett
Lever wrote:...Does anybody have any idea what could be causing it? I am starting to think it may actually be my voice itself producing it somehow. Perhaps, I should ask if you hear it in the first place? ...
The sample is short, over only a limited range (A to D) so hard to tell if the mic is contributing. But from the limited notes sung and watching the spectral analyzer, the resonance around 8-9 kHz seems to change in pitch with your voice, so my guess is it's your voice. A recording of you singing a wider scale of open mouthed vowel notes, say at least an octave, would probably help make it clearer.
Your voice reminded me somewhat of Andrea Bocelli who has a similar quality quite high up, but it hasnt seemed to have affected his success!
PostPosted: Fri Jul 03, 2020 10:32 am
by Hugh Robjohns
Lever wrote:As soon as I push a little bit with the voice, I hear a strange metallic sound in my voice. I can remove some of it but not all if I cut around 9500Hz, but I think I really need to remove it at the source rather than afterwards.
I can hear what you are talking about, but I'm pretty sure it's a natural element of your own voice.
Here's a spectogram of your recording courtesy of iZotope RX6, zoomed in to show the octave from 6-12kHz.
As you can see, there is a lot of audio signal extending up to almost 10kHz, but it all exhibits the same vibrato rate and depth, as well as the same amplitude envelope. This suggests it's all from the same source, rather than a sympathetic resonance from something else in the room or microphone, or a distortion product.
If this high frequency content is not to your liking, then I'd suggest trying some alternative microphone positions with a view to minimising the capture of such strong HF elements. I'd start by raising the mic to forehead level and point it down towards the mouth. That will help to reduce the sound element emitted through the nose which tends to have more HF elements. You could also try moving the microphone sideways -- basically try anywhere that's not directly in front of your mouth!
You could also try a different kind of mic if you have one available -- I'd recommend not using a capacitor mic. A ribbon might help, or a moving-coil mic with a smoother frequency response.
And using EQ to remove the offending elements is also an option, of course -- but do so before applying any compression or other processing!
PostPosted: Fri Jul 03, 2020 10:40 am
by Lever
I would like to thank you all for looking into this.
MOF, the reason why I moved away from the mic a bit was that I heard this "noise" when I was closer and I tried to see if moving away would change things. I will indeed redo this thing closer and see if at least the general eq gets closer to what I want. If I hear something even more evident, I'll share it.
Eddy, I know my voice sounds different when it's recorded (or simply heard by others), which is a shame, because inside my head my voice is really great :lol:
The reason why I got puzzled is that when I'm singing softly everything is normal and as soon as I start to push I believe I hear something that sounds like metal vibrating, which made me doubt the microphone, which is 25 years old and I also had to re-solder on one occasion. However, I don't have any experience in analysing the quality of sound and I trust the ears of you all way more than mine.
Tim, I confess I intentionally avoided to include hints and guesswork as much as possible in the post so that people focused on what they heard and not on what I suggested. As I mentioned, I did not write that the microphone has been DIY'ed at some point. Equally, I didn't mention that I have an 8 year old recording of me singing into a Neumann in some studio. Unfortunately, all I have is equalised and compressed voice, with reverb and a soundtrack (the finished product). Listening to it yesterday, I thought I could hear some of this resonance and wondered if my voice could be the problem.
Hugh, I will follow your advice and see what happens. I would never have hoped for such a detailed quantitative analysis and I'm really impressed. It also helps me grow my general knowledge.
And while I was already writing down all this, I tried an experiment that I considered to be pointless and perhaps it wasn't. I recorded the same 4 seconds on my phone and ignoring the hisses and noises it picked up, I do hear the same resonance, so yes, it is probably my voice, as you guys suggested. I guess I'll have to work on my technique and on my very limited equalising skills.
PostPosted: Fri Jul 03, 2020 10:59 am
by CS70
Ciao! See u sing in Italian, good to have a compatriot here.
I concur that it's likely simply your voice. I have a similar situation, in the sense that my voice may acquire a certain timbre if I push. I found two things to fix that at the source (that is me)- one is your singing technique and muscle control. If you started singing not long ago, your muscles may not yet be ready to express your full range without straining.
The other is that I noticed it particularly with specific microphones (which is why my lovely Telefunken CU-29 is used for nylon strings and female vocalists but I never pick it up for myself, while the U87 or the Peluso VTB work wonders), so a different mic can do the trick.
A ribbon mic may also do the trick - I have still to try my N22 with my own vocals but from what I've used it on, I think it would work well.
It's still worth to play with the mic position with what you have however, it may help.
PostPosted: Fri Jul 03, 2020 11:23 am
by CS70
Lever wrote:my voice sounds different when it's recorded (or simply heard by others), which is a shame, because inside my head my voice is really great :lol:
Nothing to worry - it's the same with everybody. The reason is that when you hear yourself your voice is bassier, due to bone vibrations. The mic (more or less) picks it up as it's heard by everybody else :D
PostPosted: Fri Jul 03, 2020 2:45 pm
by Lever
Grazie, CS70.
No, I haven't started singing recently, but like many amateurs who started singing as babies, I never really invested in learning how to use my voice better. I just improved and worsened over time kind of naturally without paying too much attention. I guess now I'll have to start thinking about what I do :-)
PostPosted: Fri Jul 03, 2020 3:31 pm
by CS70
Most of it is really just practice. A lot of, and consistent.
It took about a year for me, signing at rehearsals for 3-4 hours once a week plus the occasional studio session in between, to get from "can sing some" to use my full range without effort and doing damage to my vocal chords. Just the practicing strengthens muscles and control.
Now of course I don't have exactly Axl's range... :)
PostPosted: Sat Jul 04, 2020 1:31 am
by Tim Gillett
Yes there is some bone conduction. Temporarily block both ears with fingers and we get pretty much only that, but it's not much. The main reason we sound so different is because our ears are (obviously) not in front of our own mouth! Bone conduction can be used for people who have lost normal hearing from damage to the eardrum, hammer, anvil, stirrup area. It can also be set up binaurally or "stereo"!
But yes it should really help singers to know that how they hear their own voice is not how others in front of them hear it. We hear our own voice quite muffled and indistinctly. If we heard others like that we would probably struggle to understand their speech. When I'm singing onstage I want to hear through monitors how the audience hears my voice. Same with recording. Some performers don't like to hear their own voice as others hear them but for better or worse that's how it sounds.
PostPosted: Sat Jul 04, 2020 6:27 pm
by Humble Bee
All Italians I know (legio) sing. It’s in their blood. So don’t worry there will be a solution! :)
PostPosted: Sat Jul 04, 2020 6:57 pm
by CS70
Humble Bee wrote:All Italians I know (legio) sing. It’s in their blood. So don’t worry there will be a solution! :)
On a good day, I can do a passable rendition of "La Donna e' mobile" :D
PostPosted: Sat Jul 04, 2020 7:12 pm
by Humble Bee
Is that a Vasco Rossi song? :thumbup:
