Is this an M49?
Is this an M49?
Postby jodaki » Fri Sep 11, 2020 9:41 pm
Is this an M49 or is there not enough detail to tell?
jodaki
Re: Is this an M49?
Postby Hugh Robjohns » Fri Sep 11, 2020 10:06 pm
There's nothing in the image for scale, I don't remember there being so many black studs around the back, and I'm surprised there's no serial number plate visible... But despite all that I'd hazard a guess that, yes, it probably is an M49...
Re: Is this an M49?
Postby jodaki » Fri Sep 11, 2020 10:11 pm
Thanks Hugh.
jodaki
Re: Is this an M49?
Postby jodaki » Fri Sep 11, 2020 10:15 pm
Just out of curiosity do you recognise that tuchel connector. Looks very substantial...
jodaki
Re: Is this an M49?
Postby Hugh Robjohns » Sat Sep 12, 2020 12:21 am
Re: Is this an M49?
Postby Sam Inglis » Sun Sep 13, 2020 10:07 pm
Conceivably it could also be an M50, they look extremely similar from the outside.
Sam Inglis
Re: Is this an M49?
Postby Hugh Robjohns » Mon Sep 14, 2020 12:44 am
Hugh Robjohns wrote:I don't remember there being so many black studs around the back, and I'm surprised there's no serial number plate visible...
Went and refreshed my memory yesterday. The reason I didn't remember the black studs is because they're on the mounting frame rather than the mic. And the serial plate is on the sloped underside, so wouldn't be visible at that angle.
And yes, the shape is identical for an M50, although it appears to be set up for vocals with a pop screen which suggests the cardioid pattern is more likely.
