dbx 286splitting output to go into e.q.
Hi,
to those who know much more than I.
I am using a sennheiser 416 condenser mic into the 286 s as a channel strip, into a DBX 231s E.Q. then into my desk via line input on desk( zed 60 fx), but sometimes I need to use the two units to go into the camera preamp to record a demo video . just one vocal channel for Skype tuition.
To save unplugging this 1/4 inch cable from the e.q. output and then plugging into the XLR output with an xlr to xlr cable into the camera, all from channel 1, can I split the output from the single 286s output into left and right I/4 inch balanced inputs on the eq and use channel 1 out as normal into my desk and use channel 2 output of eq into my camera to save unplugging all this stuff. I have a balanced 1/4 inch splitter cable with balanced pugs on all 3 points
I called dbx harman but he wasn't sure when I asked if I could just plug into both outputs of channel 1 at same time, 1/4 and XLR as something in the book about 2 ohm load , but it did say you could use both channels at once.
I have no idea about loads, I would just have one lead in use at a time, but he said maybe having a lead hanging with no load on it may cause hum, as an incomplete circuit or something.
cheers and thanks to those who offer their time and help.
