GAP Pre 73 mkiii Issue
Postby jimh76 » Tue Sep 29, 2020 9:44 am
HI,
I bought it pre 73 second hand a few months ago and it's been working fine. Last night I was trying to put a stereo signal through this one and another one I own, but couldn't match the signals without fully boosting 1 of the pre 73s.
I've since worked out today that the output knob on 1 of the pre 73s does not do anything now. The gain knob works fine, but after putting a test tone through the unit, the output does nothing from completely off to fully on. Strangely the output LEDs in up and down as I raise and lower the output, but the test tone stays exactly the same level.
Any ideas on what this could be? I assume the output is knackered.
Anyone else had this happen?
Thanks in advance.
Jim
jimh76
Re: GAP Pre 73 mkiii Issue
Postby jimh76 » Tue Sep 29, 2020 9:58 am
DOH DOH DOH!
Just checked and the line in on my desk was coming from the insert on the pre 73, not the line out.
Sorry. :headbang:
Jim
jimh76
Postby blinddrew » Tue Sep 29, 2020 10:32 am
We've all been there in some form or other! :)
Postby Hugh Robjohns » Tue Sep 29, 2020 10:38 am
Glad you found it quickly!
If the meters reflected the output control level but the actual level didn't vary I would have suggested checking the output connections...
Been embarrassed by that kind of faux-pas before now too! :wave: :D
