Help required - ipad pro USB C - connecting Scarlett box & keyboard
Postby chrissieboy » Thu Oct 08, 2020 11:09 am
Hi all,
I have a current gen ipad pro and have been using a Focusrite Scarlett box, electric/ acoustic guitars and a condenser mic to record some cover versions in Garage band.
All has gone well and worked flawlessly but I am now wanting to add a keyboard (full size keys, 3 or 4 octave) to play garageband's synths (rather than use the on screen keyboard).
I can't seem to work out a way to add a keyboard whilst the scarlett is plugged into the only USB C port. If it exists, I suppose a USB C hub with (say) 3 or 4 additonal USB C ports would suffice?
In fact, are there any USB C keyboards available or will any keyboard like the Alesis V49 with old square USB socket with a cable to USB C suffice?
I am all very confused about what the best solution might be and one that works. I can't be the only one who wants a keyboard and audio interface connected to an ipad pro! :)
Help much appreciated!!
chrissieboy
Re: Help required - ipad pro USB C - connecting Scarlett box & keyboard
Postby shufflebeat » Thu Oct 08, 2020 6:52 pm
I've been messing about with my own iPad setup and found that a powered USB3 hub which can run off a reasonably sized power bank can handle keys, drum pad and SSL2+ happy enough without falling over.
shufflebeat
