Driving the pre-amp to hit the sweet spot without an output trim
Postby Sam the Scholar » Sun Oct 11, 2020 9:34 pm
Just watched Sam Inglis' video on Mic Pre amps - very interesting and helpful.
Due to this video I want to further understand how to use my old SPL Gold Mike to try and find the sweet spot by driving the thing - problem is it doesn't have an output trim or similar to keep output level in check - it gets loud quickly even with the level on the audio interface at very low levels.
Any thoughts on how to test this?
Audio interface is focusrite liquid saffire 56 - due to the pre-amps on this haven't used the Gold Mike for years but this video has got me thinking that it might add something nice if I can find the right spot !
Thanks,
Sam
Sam the Scholar
Re: Driving the pre-amp to hit the sweet spot without an output trim
Postby Hugh Robjohns » Sun Oct 11, 2020 10:08 pm
If you can't turn down the line inputs of the interface enough, then you'll need to introduce a pad between the preamp and interface. You can buy inline XLR pads for 10-40dB attenuation easily enough. Alternatively, you can use a passive monitor controller to serve as a variable pad. I have often used the (JBL) Nanopatch for the role, for example, and it works very well!
Postby Sam the Scholar » Mon Oct 12, 2020 7:57 am
Brilliant, thanks Hugh
Sam the Scholar
Postby Guest » Mon Oct 26, 2020 3:08 am
That should be easy if you can replace the 12ax7 with a 12au tube to reduce the amount of gain the tubes produce.
Guest
