Miking classical violin and, sometime, piano: beginner questions
I am struggling with recordings basics and I hope you could have some tips.
This what I would like to record:
• Violin solo
• Violin and Piano
• Trio, Quartet and Quintet (prio 2)
This is the equipment I have today:
• Zoom f8n
• RODE NT55 stereo marched pair with both cardioid and omni capsules.
• DAW: Studio One 3 Artist
I am considering in upgrading the mics. I find the Rodes too bright/harsh and I would like to get a better pair of mics that could give me a good and warm balanced main stereo image (max budget 2000€).
I was considering Neumann KM184 (cardioid) or KM183 (omni) in stereo matched pair. I like more the Omni as I find the X/Y quite boring and a bit too ”narrow”.
Maybe you have some tips about other types?
Just to not to be too theoretic, let’s make 4 examples:
1. Violin solo recording in medium size concert hall
2. Violin and piano recording in church
3. Violin and piano recording in medium size concert hall
4. Piano Violin Cello Trio in medium size Concert hall
• Maybe 2 mics for the main stereo image and spot mics only if necessary?
• Which mic technique, mic type and setup would you advise me to play with for these 4 examples?
• How do you usually deal with phase cancellation in AB or spaced pair setups?
• How do you usually mix the different tracks (main stereo image, spot, ambient)
• How do you work with delays?
I know these questions do not have direct/unique answers because all the factors that can generate huge differences depending on the application. Anyway I will find very valuable your opinion and comments.
The sound engineer we usually works with has the same ZOOM F8n but very expensive mics and of course a lot of knowledge within the subject.
He usually get the main stereo image with 2 Pearl elm-A pretty far away up together with DPA 4011 as spot mics in case of need of more definition (usually one for the violin and 2 inside the piano).
Sometimes he has only used the 2 PEARL elm-A without spot mic.
Thanks a lot for your time and will to help :-D
• Violin solo
• Violin and Piano
• Zoom f8n
