Good points Sam, in fact if Cubase is not set in stone it is worth delaying any kind of spend on a DAW for a few months. Most of the majors are available as a 30 day trial download so 'play the field' for a time?
Headphones and monitor recommendations
• Page 2 of 2 • 1, 2
- ef37a
- Jedi Poster
Re: Headphones and monitor recommendations
Hi Thanks everyone for the recommendations. Getting Cubase Pro 11 Education, he has used it before many years ago!
punkyfish - Poster
Sam Spoons wrote:(and you can save at least £25 buy buying him a Reaper licence for £60 if Cubase is not an absolute requirement)
Arpangel - Jedi Poster
Can't ague with Reaper for value, but if he's used to Cubase it's still the best DAW out there IMO, and well worth its money.
The Elf - Jedi Poster
The Elf wrote:Can't ague with Reaper for value, but if he's used to Cubase it's still the best DAW out there IMO, and well worth its money.
Yes, I’ve got CB on my i Pad, it’s very seductive, may even tempt me over, but I’d never forsake Reaper.
If he used Cubase 'years ago' I suspect the learning curve will be nearly as steep as starting from scratch with a new DAW (it was when I had to choose again after 8 years recording purely in hardware and the difference in cost between Reaper and Cubase (currently £60/£499) was more than enough to sway me).
But if Cubase is what he wants then go for it.
Sam Spoons - Jedi Poster
Sam Spoons wrote:If he used Cubase 'years ago' I suspect the learning curve will be nearly as steep as starting from scratch with a new DAW (it was when I had to choose again after 8 years recording purely in hardware and the difference in cost between Reaper and Cubase (currently £60/£499) was more than enough to sway me).
And, do we know the power of the computer involved? Cubase was always resource hungry and if OP is a bit 'cash light' atmo might be running an old machine and C11 could be a no no?
Reaper is well known for its CPU efficiency.
- ef37a
- Jedi Poster
