quiet kick pedal
quiet kick pedal
Postby MadManDan » Fri Nov 20, 2020 8:31 pm
Hi all.
I’m considering getting a kick drum pedal for my drum programming. To supplement what I play on a keyboard.
Any drummers know of a pedal that is really mechanically quiet? I know my foot will be tapping it. Other than that, I don’t need my neighbors hearing me playing through the thin walls here.
MadManDan
MadManDan
Late '14 mini 3 GHz i7 16 GB
Catalina 10.15.7. Glyph atomic. FF Scarlet 18i8.
Sup Drum 3. Cubase 11 Pro
iCon iKb 8x.  Mics, spkrs, 'phones, gtrs, greedy cat
Re: quiet kick pedal
Postby RichardT » Fri Nov 20, 2020 8:37 pm
MadManDan wrote:Hi all.
MadManDan
What will the pedal be hitting? In my experience kick drum pedals themselves are quite quiet, you may hear a slight rattle when you play it.
RichardT
Postby MadManDan » Fri Nov 20, 2020 8:43 pm
RichardT wrote:...What will the pedal be hitting? In my experience kick drum pedals themselves are quite quiet, you may hear a slight rattle when you play it.
But there is the sound of the beater hitting the pad. . so here's what I'm thinking. I'm not a drummer, I don't need all the resolution of hitting something hard.
I'm thinking more like a drum pad I can actually hit with my foot. It won't be as accurate as a proper foot driven beater type affair, but would still suffice. I plan on usually editing the midi data later to really perfect the dynamics. As long as this gets me in the ballpark. I think Roland has a new product like this, not sure.
I mean, hell, now I have a sustain pedal that's got a rubber stop. For the moment I'm considering plugging that in, and using cubase to turn sustain messages into midi note 36. Obviously, that has a resolution of...none :headbang:
MadManDan
Postby BJG145 » Fri Nov 20, 2020 8:54 pm
Roland KT-10.,..? No pad.
The KT-10 has a fast and fluid response to your footwork with an all-in-one design and a reverse action trigger mechanism that means the pedal is far quieter than a kick pad played with a standard pedal and beater. In fact, it produces approximately 75% less noise than a Roland KD-9 kick pad and beater.
https://www.gear4music.com/Drums-and-Pe ... yQQAvD_BwE
https://www.youtube.com/watch?v=Xm6gt3KY5T0
I think there are also other electronic kick pedals that don't use pads...
Postby MadManDan » Fri Nov 20, 2020 9:13 pm
BJG145 wrote:Roland KT-10.,..? No pad.
ooooh nice. Now we're talking. I like that it uses the same action as a real pedal without the noise.
MadManDan
Postby BJG145 » Fri Nov 20, 2020 10:23 pm
I was looking at these years ago...there's also this Yamaha one...
https://www.pmtonline.co.uk/yamaha-ku10 ... GQQAvD_BwE
...but I think the Roland came out tops back then.
The KT-9 is slightly cheaper.
