Capstan Dirty after almost every playback - Tascam TSR-8.
Re: Capstan Dirty after almost every playback - Tascam TSR-8.
Postby bruceyripper » Wed Nov 25, 2020 11:46 am
bruceyripper
Postby bruceyripper » Wed Nov 25, 2020 11:51 am
There ya go. Front. I know what a capstan is :roll:
I was showing you the inside because someone mentioned that grease might be working it's way from the inside to the rest of the rollers. :tongue:
bruceyripper
Postby blinddrew » Wed Nov 25, 2020 1:23 pm
Can't see the image here I'm afraid.
Postby Hugh Robjohns » Wed Nov 25, 2020 1:35 pm
It's working for me!
Postby Kwackman » Wed Nov 25, 2020 1:49 pm
Hugh Robjohns wrote:It's working for me!
Not for me.
Clicking on the link gives an "this image failed to load" message.
Mac using Safari
Kwackman
Postby Hugh Robjohns » Wed Nov 25, 2020 2:00 pm
Here it is as a direct image...
Postby Folderol » Wed Nov 25, 2020 3:44 pm
Ah. That's much clearer. So is the OP actually talking about the capstan or that front guide?
Yes. I am that Linux nut.
Postby Sam Spoons » Wed Nov 25, 2020 3:50 pm
For clarity the capstan is half visible on the extreme right of that pic, separate from the headlock assembly and, as TG points out, is not visible in the OPs first pic.
Postby Hugh Robjohns » Wed Nov 25, 2020 4:15 pm
Here is his other pic as a direct image lest that was also not visible to some. it gives a fuller view of the capstan:
Postby Tim Gillett » Wed Nov 25, 2020 9:25 pm
On the guides, heads, lifters, capstan and pinch roller I don't see much dirt or oxide.
Tim Gillett
Postby bruceyripper » Wed Nov 25, 2020 9:27 pm
Exactly Tim!
So would you think this is just the tension and nothing more? Please say yes.
bruceyripper
Postby bruceyripper » Wed Nov 25, 2020 9:28 pm
I've got the guy coming over tomorrow so will let you know if he sorts it out.
I'm going to mention the things brought up on here.
You know when you just want to make music.... :thumbdown:
bruceyripper
Postby James Perrett » Wed Nov 25, 2020 9:29 pm
Can you post a picture with the dirty capstan? It looks fairly clean in those pictures.
Postby bruceyripper » Thu Nov 26, 2020 10:05 am
bruceyripper
Postby bruceyripper » Thu Nov 26, 2020 10:11 am
So the picture above is the dirt that comes off.
As I said, it only requires 2 wipes and then it's clean again, BUT, this is happening after EACH play through, which I would presume is not normal.
I think the tension explanation seems to be on point so far. Although I have slacked the tension and now it doesn't happen after every single play back, but is still happening after 3 play backs.
I know cleaning is all part and parcel of reel to reel, but everything I've heard and read states cleaning is only required, beginning/end and every 2 hours or so in the session, NOT, after each play back or indeed after 2 or 3 playbacks, which I believe is not normal and means something is up. Right?
:think:
bruceyripper
PreviousNext
