Capture reverb
• Page 1 of 2 • 1, 2
Capture reverb
I'm working in Pro Tools and was wondering what is the most effective way - if there's a way - to capture the reverb from one track onto its own track to be used separately? I am working only with stock plugins. Thanks in advance.
nickle15 - Regular
Re: Capture reverb
Not familiar with pro-tools but can't you just send the output to a new track and set that to record the send?
blinddrew - Jedi Poster
Re: Capture reverb
I'm not a PT user either, but it should be possible as Drew says.
But, it probably won't work if you've inserted the reverb into an audio channel.
The reverb would need to be on a separate FX channel (if that's what it's called in PT) and fed by an auxiliary or FX send from the audio channels you want to add the reverb to.
I'm sure there's a clearer way to explain that!
Kwackman - Frequent Poster (Level2)
Re: Capture reverb
Thanks guys! That worked very well. I appreciate the feedback!!
nickle15 - Regular
Re: Capture reverb
Ok, I jumped the gun and didn't accomplish what I meant to. When I went back to my original question I realized I might not have been clear so I'd like to re-open this topic.
Here's the scenario:
I have a vocal track that has been recorded dry. I will add a reverb plugin to the track to add reverb to the vocal. Is there a way to then have another track that captures ONLY the resulting reverb generated by the plugin without also bringing in the source vocal? I just want to capture the "echo" on its own track.
nickle15 - Regular
Re: Capture reverb
You shouldn't add a reverb plugin on the vocal channel, as you're just mixing the vocal and reverb at that point into one combined signal - whereas you specifically want them to remain separate.
You should follow more conventional reverb routing, and put the reverb on a bus, and send from the vocal channel to that bus. That way your vocal and the reverb for that vocal remain independent signals, and cab be routed/recorded independently in whatever way you want.
desmond - Jedi Poster
mu:zines | music magazine archive | difficultAudio
Re: Capture reverb
Thanks for that. I misspoke there. So my experiment the other day involved the use of three tracks.
1. Vocal audio track (dry, with no plugin)
2. Aux track with reverb plugin
3. Blank audio track
My setup was track 1 output to bus 1 - input of track 2 was bus 1, and output was bus 2 - input of track 3 was bus 2.
So I think I might be close, but the result of this experiment was the reverb and vocal both landing on track 3.
nickle15 - Regular
Re: Capture reverb
I suspect you have the wet/dry mix on the reverb set wrongly. It should be 100% wet.nickle15 wrote:Thanks for that. I misspoke there. So my experiment the other day involved the use of three tracks.
The Elf - Jedi Poster
Re: Capture reverb
The Elf wrote:I suspect you have the wet/dry mix on the reverb set wrongly. It should be 100% wet.nickle15 wrote:Thanks for that. I misspoke there. So my experiment the other day involved the use of three tracks.
I'll certainly give that a look. Sorry for my lack of knowledge here but would the wet/dry mix be responsible for removing the source vocal audio?
nickle15 - Regular
Re: Capture reverb
Yes, that's the point. When you use a reverb on a send (as you should - not as a track insert), then you want it 100% wet.
I think you're routing the vocal to the reverb track - don't do that. Use a send. In Logic-speak (I don't use Logic) I think that's a 'Aux'.
Re: Capture reverb
nickle15 wrote:Sorry for my lack of knowledge here but would the wet/dry mix be responsible for removing the source vocal audio?
Yes, it's the blend between the dry (incoming vocal signal) and the generated reverb signals.
Your dry vocal signal is handled on the original channel - so you should set your reverb to 100% wet to *only* output the reverb signal. You should always do this on FX processors on aux channels used like this.
Re: Capture reverb
The Elf wrote:I think you're routing the vocal to the reverb track - don't do that. Use a send.
+1
The Elf wrote:In Logic-speak (I don't use Logic) I think that's a 'Aux'.
No, in Logic it's "Sends" to a "Bus" which ends up in an "Aux" channel.
But I think the OP is in ProTools anyway.
Re: Capture reverb
Yeah, I find both the Logic and PT nomenclature baffling! Ta! :thumbup:desmond wrote:No, in Logic it's "Sends" to a "Bus" which ends up in an "Aux" channel.
Re: Capture reverb
desmond wrote:The Elf wrote:I think you're routing the vocal to the reverb track - don't do that. Use a send.
+1The Elf wrote:In Logic-speak (I don't use Logic) I think that's a 'Aux'.
Yes, I'm in Pro Tools but I followed. Thanks!
nickle15 - Regular
Re: Capture reverb
So I think part of my confusion resulted from thinking the wet/dry mix was keeping the dry audio signal in place and just adding more and more reverb as you cranked it up. If I understand correctly it's more a matter of adjusting the actual ratio of the source audio to the resulting reverb. In other words, the higher the wet level the lower the dry signal gets.
Do I have that right?
nickle15 - Regular
