If you can source 50mm RW3 or similar a simple frame made from 2" x 1" planed timber so the rockwool batt is a snug fit will, when covered with fabric (I used Camira Cara fabric bought from Gik Acoustics), provide sufficient support as the RW3 is stiff enough to mostly support itself. I have 4 panels on the ceiling, the largest are 1200 x 600mm x 50mm RW3 and am going to add another 3, plus at least couple more on the walls.
I keep meaning to make a drawing of the construction details, it's pretty obvious but if it would help I'll do one and post it here.
Room treatment and monitor speakers suggestions.
• Page 2 of 3 • 1, 2, 3
Sam Spoons - Jedi Poster
Re: Room treatment and monitor speakers suggestions.
Sam Spoons wrote:If you can source 50mm RW3 or similar a simple frame made from 2" x 1" planed timber so the rockwool batt is a snug fit will, when covered with fabric (I used Camira Cara fabric bought from Gik Acoustics), provide sufficient support as the RW3 is stiff enough to mostly support itself. I have 4 panels on the ceiling, the largest are 1200 x 600mm x 50mm RW3 and am going to add another 3, plus at least couple more on the walls.
Thanks Sam, much appreciated :)
Murray
Mus - Regular
Murray Webster London Songwriters - Collaboration Songshare Retreats Community
Mus wrote:The Presonus 3.5s with Bluetooth look like they might be perfectly adequate and quite portable too - been looking for something like those for a while :)
Cheers
Murray
Does anyone know what floor stands would be suitable for these monitors? I think it's my only option at the mo'
Thanks!
M
Mus - Regular
Rough sketch of how I made my panel frames (not to scale).
I used a batten or two across the back to space them off the wall/ceiling and act as an invisible (mostly) fixing.
I bought the Adams TV7's not cos of price but due to the sound quality and their 5 year warranty. Looking at the size of your room the 5s would be plenty big enough and slightly cheaper. I considered the choice of studio monitors as my top priority where I saved elsewhere I spent on what I considered the best value all round speakers.
- uselessoldman
- Regular
Mus, been centuries dude. Lovely to have you here my friend.
Zukan - Moderator
Zukan wrote:Mus, been centuries dude. Lovely to have you here my friend.
Cheers Ed, been stupid busy but have a new room to use :)
Mus - Regular
Sam Spoons wrote:Rough sketch of how I made my panel frames (not to scale).
Many thanks for that Sam, much appreciated. Will take a look at that as a project :)
Murray
Mus - Regular
uselessoldman wrote:I bought the Adams TV7's not cos of price but due to the sound quality and their 5 year warranty. Looking at the size of your room the 5s would be plenty big enough and slightly cheaper. I considered the choice of studio monitors as my top priority where I saved elsewhere I spent on what I considered the best value all round speakers.
Thank you uom, will check those out.
Do they have any provision for mounting on stands or would a universal stand with a plate do?
Cheers
M
Mus - Regular
Mus wrote:Many thanks for that Sam, much appreciated. Will take a look at that as a project :)
Murray
You're welcome. :thumbup:
If you're going to be making a few, and you don't already own one of these, I'd serious recommend £11 of your cash heading that way: https://www.diy.com/departments/corner- ... 804_BQ.prdMus wrote:Many thanks for that Sam, much appreciated. Will take a look at that as a project :)
Murray
blinddrew - Jedi Poster
blinddrew wrote:If you're going to be making a few, and you don't already own one of these, I'd serious recommend £11 of your cash heading that way: https://www.diy.com/departments/corner- ... 804_BQ.prdMus wrote:Many thanks for that Sam, much appreciated. Will take a look at that as a project :)
Murray
Cheers blinddrew will take a look.
Here is how the working end of the room is shaping up. I usually use a laptop with the two external screens but I'm not sure where the monitors e.g. Presonus Eris 3.5s are going to go especially as floor stands seem to be 44cm triangular bases? Bit cramped.
Is there a wall mount for monitors or any other suggestions for organising the space? Not sure I want to drill into the walls too much but we'll see.
Cheers
Murray
Mus - Regular
You could build free standing shelf over the top of the organ and wide enough to fit the monitors (computer) and the monitors (audio). place a back brace below the hight of the organ so it can stabilise the shelf and remove the need for screws into the wall.
Sam Spoons wrote:You could build free standing shelf over the top of the organ and wide enough to fit the monitors (computer) and the monitors (audio). place a back brace below the hight of the organ so it can stabilise the shelf and remove the need for screws into the wall.
Cheers Sam, yes, you're right, I'll look into it :)
Murray
Mus - Regular
Mus wrote:Sam Spoons wrote:You could build free standing shelf over the top of the organ and wide enough to fit the monitors (computer) and the monitors (audio). place a back brace below the hight of the organ so it can stabilise the shelf and remove the need for screws into the wall.
Murray
Actually guys, any ideas where to get an off-the-shelf shelf 6ft by 1ft - or one cut to size?
Cheers
M
Mus - Regular
