Room treatment and monitor speakers suggestions.
Re: Room treatment and monitor speakers suggestions.
Postby Saxum esse et non provolvere » Sat Jan 16, 2021 7:51 pm
See what you did there ...
I’ve received good service from https://skirtingboardsdirect.com/.
Postby Mus » Mon Jan 18, 2021 11:56 am
Saxum esse et non provolvere wrote:See what you did there ...
Ha, thanks Saxon. Actually I misread my ancient tape measure which has 83cm not 183cm against 6ft which I then misread as 8300mm, I searcheth and unsurprisingly foundeth not, hence the confusion :headbang:
Takes a while but I mostly get there eventually :lol:
Presumably I just need a solid pine 1800 x 300 x 18mm. I'm thinking I might just bracket it to the side of the organ so it's more easily removable and won't bend with the speakers balancing on the end.
Cheers
M
Mus
Murray Webster London Songwriters - Collaboration Songshare Retreats Community
Postby Sam Spoons » Mon Jan 18, 2021 12:59 pm
Postby Mus » Mon Jan 18, 2021 4:01 pm
That's great, thanks Sam. Yes '18mm' was a bit of a punt and begged the thinness question.
Quite hard to find something reasonably priced at 1800mm x 30+mm. Best I've done so far is 27mm:
https://www.atlantictimber.co.uk/craftpine27.html
which is £50 delivered and untreated wood. Ideally black would be good to go with the organ, but hey :)
A custom finished wood site is coming in at £150.
M
Mus
Postby Murray B » Mon Jan 18, 2021 4:18 pm
if the 16mm versions are significantly cheaper - ie less than half the price of 30mm you could always stick two to together - glue and screw will be just as strong.
Hello fellow Murray - you don't see many of us about :-)
Murray B
Postby James Perrett » Mon Jan 18, 2021 4:31 pm
An alternative is to go for a thinner plank but screw a batten onto the back to give it more stiffness.
Postby Sam Spoons » Mon Jan 18, 2021 4:38 pm
27mm should be fine TBH.
Postby Mus » Mon Jan 18, 2021 5:15 pm
Murray B wrote:if the 16mm versions are significantly cheaper - ie less than half the price of 30mm you could always stick two to together - glue and screw will be just as strong.
Cheers Murray.
Yes, you grow up feeling 'different' and then accept that actually it's great to be not the same as everyone else :)
M
Mus
Postby Mus » Mon Jan 18, 2021 5:17 pm
James Perrett wrote:An alternative is to go for a thinner plank but screw a batten onto the back to give it more stiffness.
Thank you James, will consider the options.
Hope you are keeping well :)
M
Mus
Postby Mus » Mon Jan 18, 2021 5:20 pm
Sam Spoons wrote:27mm should be fine TBH.
I think so. Thanks Sam.
Strange that B&Q or Wickes etc. don't have 1800mm as a length. Lots of sites seem to stop at 1500mm.
I may leave untreated for the time being and maybe treat myself to a paint job in the Spring or something if I fancy it :)
Cheers and thanks for all your help.
M
Mus
Postby Murray B » Mon Jan 18, 2021 6:17 pm
Cheers Murray.
M
Indeed :-)
Murray B
