See what you did there ...
I’ve received good service from https://skirtingboardsdirect.com/.
Room treatment and monitor speakers suggestions.
• Page 3 of 3 • 1, 2, 3
- Saxum esse et non provolvere
- Regular
Re: Room treatment and monitor speakers suggestions.
Saxum esse et non provolvere wrote:See what you did there ...
Ha, thanks Saxon. Actually I misread my ancient tape measure which has 83cm not 183cm against 6ft which I then misread as 8300mm, I searcheth and unsurprisingly foundeth not, hence the confusion :headbang:
Takes a while but I mostly get there eventually :lol:
Presumably I just need a solid pine 1800 x 300 x 18mm. I'm thinking I might just bracket it to the side of the organ so it's more easily removable and won't bend with the speakers balancing on the end.
Cheers
M
Mus - Regular
Murray Webster London Songwriters - Collaboration Songshare Retreats Community
I'd go for 30mm+ thickness, 16mm is a bit thin for my taste. With that it would probably be sufficient to use some non slip matting on top of the organ. https://www.amazon.co.uk/Levish-New-Multipurpose-Non-Slip-Mat/dp/B07J68VSS4/ref=sr_1_1_sspa?dchild=1&keywords=non+slip+mat&qid=1610971065&sr=8-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUFPTjQxODFIVUJKSlQmZW5jcnlwdGVkSWQ9QTA1Mjc4NDUySFBGNkdSMkFOTzJBJmVuY3J5cHRlZEFkSWQ9QTA1Mzc5MDFTUFBOMEI4R0ZaRDImd2lkZ2V0TmFtZT1zcF9hdGYmYWN0aW9uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl
Sam Spoons - Jedi Poster
Sam Spoons wrote:I'd go for 30mm+ thickness, 16mm is a bit thin for my taste. With that it would probably be sufficient to use some non slip matting on top of the organ. https://www.amazon.co.uk/Levish-New-Multipurpose-Non-Slip-Mat/dp/B07J68VSS4/ref=sr_1_1_sspa?dchild=1&keywords=non+slip+mat&qid=1610971065&sr=8-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUFPTjQxODFIVUJKSlQmZW5jcnlwdGVkSWQ9QTA1Mjc4NDUySFBGNkdSMkFOTzJBJmVuY3J5cHRlZEFkSWQ9QTA1Mzc5MDFTUFBOMEI4R0ZaRDImd2lkZ2V0TmFtZT1zcF9hdGYmYWN0aW9uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl
That's great, thanks Sam. Yes '18mm' was a bit of a punt and begged the thinness question.
Quite hard to find something reasonably priced at 1800mm x 30+mm. Best I've done so far is 27mm:
https://www.atlantictimber.co.uk/craftpine27.html
which is £50 delivered and untreated wood. Ideally black would be good to go with the organ, but hey :)
A custom finished wood site is coming in at £150.
M
Mus - Regular
if the 16mm versions are significantly cheaper - ie less than half the price of 30mm you could always stick two to together - glue and screw will be just as strong.
Hello fellow Murray - you don't see many of us about :-)
Murray B - Regular
An alternative is to go for a thinner plank but screw a batten onto the back to give it more stiffness.
James Perrett - Moderator
27mm should be fine TBH.
Murray B wrote:if the 16mm versions are significantly cheaper - ie less than half the price of 30mm you could always stick two to together - glue and screw will be just as strong.
Cheers Murray.
Yes, you grow up feeling 'different' and then accept that actually it's great to be not the same as everyone else :)
M
Mus - Regular
James Perrett wrote:An alternative is to go for a thinner plank but screw a batten onto the back to give it more stiffness.
Thank you James, will consider the options.
Hope you are keeping well :)
M
Mus - Regular
Sam Spoons wrote:27mm should be fine TBH.
I think so. Thanks Sam.
Strange that B&Q or Wickes etc. don't have 1800mm as a length. Lots of sites seem to stop at 1500mm.
I may leave untreated for the time being and maybe treat myself to a paint job in the Spring or something if I fancy it :)
Cheers and thanks for all your help.
M
Mus - Regular
Mus wrote:Murray B wrote:if the 16mm versions are significantly cheaper - ie less than half the price of 30mm you could always stick two to together - glue and screw will be just as strong.
Cheers Murray.
M
Indeed :-)
Murray B - Regular
