merlyn wrote:James Perrett wrote:N i g e l wrote:Its a PC software problem, which will eventually be fixed, given time.
Don't hold your breath - it is a long standing problem with ASIO drivers.
It's not an ASIO problem. If that was the case it's also a WDM, WASAPI, Direct Sound and any other driver problem.
I'm fairly sure that in the early PC DAW days (twenty years ago or more) there were programs that could use more than one interface for recording simultaneously using either the WDM or Direct X drivers. Possibly Cakewalk Pro Audio?
