Hi Everyone - new user here. Experienced musician but novice home recorder.
I recently got a LIne 6 UX2 interface, which obviously comes with Pod Farm. I also bought a Rode NT1-A. Both items brand new.
I plug the mic into the UX2, phantom power on, and fire up pod farm and the preset male lead vocal tone. However, I can get virtually no sound from the mic in my headphones (the headphones are fine) unless I increase either the mic gain on the UX2 unit or the DI level in the mixer view of Pod Farm to the point where there is so much white noise and static that the sound is unusable.
I'm trying to figure out if I am missing a simple set up trick, or if there is a problem with either piece of hardware. I have managed to record some guitar through the UX2 and it's fine, although it's quieter than I expected it to be in terms of monitor (headphones) output.
Sometimes I fire up pod farm and I can see the mic is registering some noise but I get nothing at all through the headphones. PF seems a bit flaky generally.
The only thing I've been able to swap out is the XLR cable and it makes no difference.
I'm using a pretty much brand new Dell Inspiron 15 7000 laptop. The other thing I wondered was whether it could be something to do wtih the fan?
If anyone has advice or similar experiences I would love to hear about it!
Thanks!
Vocal recording problem Rode NT1-A and Line 6 UX2
• Page 1 of 1
- BroadbridgeMIke
- New here
Re: Vocal recording problem Rode NT1-A and Line 6 UX2
Which DAW are you using? Can you get a clean recording going straight into the DAW? If not how are you seeing that you are getting signal into the computer?
WRT the quiet signal when recording guitar, getting the gain structure through the system is important but it is normal for the recorded signal to be fairly quiet or showing a small waveform in the DAW as, if set correctly, you should have peaks no higher than -10 dBFS and an average level of around -18 dBFS. After recording and mixing it is normal to have to increase the level quite a lot to match that of commercial recordings.
Sam Spoons - Jedi Poster
As I understand it , the LIne 6 applies phantom power using 2 x switches - one for inputs 1-4 , one for 5-8 - assuming the correct input is selected , just wondering if there's enough juice for the Rode ; I'm unsure how the power is shared between all four/eight inputs even though only one input being utilised.
Do you have a dynamic microphone you can try without the need for phantom power - will need more gain but should still work as expected and allow signal to pass through to the phones .
Can you try without using a preset - perhaps there is a noise gate as part of the preset with an incorrect threshold setting .
- wdsteele
- Regular
Thanks for your replies.
So I tried using my 58 Beta A and it works absolutely fine. No weird background noise with or without the preset. Loud and clear. So that's progress.
Does this suggest the Rode is faulty? This Line 6 unit has two mic inputs and two instrument, and claims 48v phantom power. The problem with the Rode is the same in both mic inputs.
- BroadbridgeMIke
- New here
Have you got access to a mixing desk that can supply phantom power so you can test the mic? Might help work out if it's the mic or the interface.
Or vice-versa can you get hold of another mic that requires phantom power?
Ideally both
And finally do you have a volt meter to measure how much juice the line 6 is putting out?
Apologies if this is patronising- just taking you through how I'd go about initial fault finding.
Ideally both
Murray B - Regular
Thanks Murray - no apology needed. I may be able to get hold of another mic to test.
Would insufficient phantom power manifest as lots of white noise?
Mike
Mike
- BroadbridgeMIke
- New here
For some reason I read UX2 as UX8 , dunno why ...,sorry for confusion.
But same principal , may not be enough power , phantom power not working or the Rode could be faulty.
- wdsteele
- Regular
just to be clear - have you switched the phantom power on using the little switch on the back?
Kwackman - Frequent Poster (Level2)
Kwackman wrote:just to be clear - have you switched the phantom power on using the little switch on the back?
Hi - yes the problem happens when Phantom power is on. When PP is off, the mic generates no signal.
- BroadbridgeMIke
- New here
Do you have acces to a local musician, DJ or radio person who might have some other gear to plug the nt1a into?
- shufflebeat
- Jedi Poster
Apologies for this incredibly basic question...but I went through a similar diagnostic with someone a few weeks ago...you are using the correct side of the mic?
Aural Reject - Frequent Poster
Aural Reject wrote:Apologies for this incredibly basic question...but I went through a similar diagnostic with someone a few weeks ago...you are using the correct side of the mic?
Ha, no problem. I was, but without realising it was a requirement. Discovered in my first Google search trying to solve the issue.
- BroadbridgeMIke
- New here
shufflebeat wrote:Do you have acces to a local musician, DJ or radio person who might have some other gear to plug the nt1a into?
Off on that quest tomorrow morning. Tricky in lockdown but there is a guy I know who has some gear I can test. Seems clear there is a fault in one bit of hardware.
- BroadbridgeMIke
- New here
I tried an AKG Perception through the UX2 and it worked absolutely fine.
Looking like the Rode is at fault.
thanks for your comments.
Mike
Mike
- BroadbridgeMIke
- New here
I think you might be suffering from the occasional curse of buying a capacitor mic in winter. I've had it a couple of times.
A mic is despatched from a cool/cold warehouse and goes through lots of cold transport processes, ending up in the back of a cold delivery van for a few hours. Then it's brought into a nice warm house... and bingo! condensation forms on the capsule.
It could be that, but it could just be a duff one. The usual recommendation is to put the mic in an airing cupboard in an open-ended plastic bag to cover it and leave it there for a couple of days. Sometimes sorts it; I've had some success putting suspect mics in our boiler-cupboard!
Jus' a thought...
Jus' a thought...
- Mike Stranks
- Jedi Poster
