cubase tempo map - well that's wierd
Postby MadManDan » Wed Jan 20, 2021 6:09 am
Hi all
Loving cubase pro 11, and have started delving into making tempo maps. Had a really strange experience. I played a midi click along with a song, and tweaked it to perfection.
I made sure the midi was clean in the list editor. No strange controllers, etc. Then fed it into "tempo detection" Well, the map worked... all except one small section. It was as if cubase detected a stray click and the map went out the window. Tried repeatedly. Same result.
Could not for the life of me figure out why. So I turned it into audio, and fed cubase that. Worked perfectly
Things that make you go hmmmmm
MadManDan
MadManDan
Late '14 mini 3 GHz i7 16 GB
Catalina 10.15.7. Glyph atomic. FF Scarlet 18i8.
Sup Drum 3. Cubase 11 Pro
iCon iKb 8x.  Mics, spkrs, 'phones, gtrs, greedy cat
