CS70 wrote:
There's the difference between can and need. :lol:
Yeeeesss, that’s always been a difficult one for me.
DigitalMusicProduction wrote:CS70 wrote:If the peaks are anywhere 0dBFS, the first thing to do is to lower the gain level of the channel containing the instrument, so that your loudest playing peaks around -12dBFS on the DAW meter and no higher. If it sounds too low, turn up your playback volume.
When you say the gain level of the channel containing the instrument, which of the two are you referring to, the gain level of the instrument track in Logics workspace? Or the instrument channel strip volume fader in Inspector?
I believe both will act in doing the same thing? But just to be sure..
