uselessoldman wrote:If I were adding audio inputs in the numbers you are considering I think I would rethink my strategy and go down another route rather than a audio interface with ADAT type extensions.
I have the Liquid 56 and ADA8200 which is great for vocals guitars etc but you are adding/wanting a lot of inputs that may or may not be utilised all the time sat idle taking up input space/slots?? I have my gear in a small cabinet and I added the MS800 to my setup which goes into the back of my Liquid 56. AS its inputs are on the front of the cabinet I can swap out the input source/xlr without going to the back of the interface. But I also bought a snake box that goes from the MS800 and ADAT8200 to anywhere I want and from there xlr cables to the source. Add into that I added a Samson x-Patch plus that sits between the audio interface/ADAT and the MS800 and a Di-Pro I can also use that to break add in mix the channels in any way I want. SO I have potentially a lot of inputs available if only 16 in use/available at any one time.
If I were doing it all again from scratch I would probably get the Behringer X-Air 18 or X32, which I am seriously thinking about buying as a control surface and mobile recording desk.
To tell you the truth I will have to read this a few more time to figure it out. :crazy:
I was thinking of getting an ASP800 and eventually sell my focusrite to get a 2nd ASP800 with the Audient IDxx. I doubt I will need more inputs at once, so I figured I'll add a patch bay and call it a day.
What do you think?
