Hugh Robjohns wrote:I'm not entirely clear what you're doing here -- is the bass drum miked and going through the desk (and with the channel gain aligned using the PFL method as you described), or is this ambient spill picked up by the SM57?
Either way, the problem is a lack of headroom in the interface because you've wound its input sensitivity up.
If it's acoustic spill, being picked up by the SM57, the most likely reason for the apparently excessive signal level is that the mic is in a resonant chamber formed by the piano and its lid that happens to over-emphasise the bass drum fundamental, and/or it's positioned in an anti-node of the room's standing waves that do the same thing.
Ambient spill picked up by the SM57 in the piano. That was the only mic on.
I have a much better piano mic setup now thanks to you guys ;)
Thank you kindly to Hugh who patiently worked through all of my other piano lid issues on a previous thread! Getting away from the lid sound was a huge improvement for me. And I get many comments from folks who want me to make piano tracks for them cause they dig my sound! :D
But I still like to try the SM57 style mics to hear how they sound on other stuff where the mic is not right up close, and sometimes it is just right! The extra preamp gain is needed to avoid these kinds of dynamic range problems with my system. I just want to get a proper level (via PFL procedure), be able to hear it in the headphone even though I am in the same room, and not clip! We are calling that 'head room' - being able to absorb big stuff without clipping.
