Hi
I'm very short on floor space and ideally would like to use my Aston Halo reflection filter (and microphone) on a clamped microphone arm stand.
Can anyone recommend one which will take the weight of the Halo and mic, such as the SE Electronics Z330A?
Boom mic stand for Aston Halo?
• Page 1 of 1
Re: Boom mic stand for Aston Halo?
Consider not having a floor-standing support: hang an arm from a movable support clamp on a horizontal bar nearer the ceiling. The Halo and mic are just as effective upside-down.
Take this idea from the photography and video and lighting environment.
Floor space might only be taken by vertical columns in corners. Run a horizontal bar clamped between the columns. The bar might also serve as a hanger for sound-control blankets or panels.
Many flexible commercial brands and parts are widely available.
I've used common steel pipe and fittings for some support projects; the clamps and such are more specialized.
- allebaug
- Poster
Hi, thanks for your reply. I realise I'd worded my question poorly! I meant an arm not a stand.
I like the idea of a horizontal bar no the way, although I'm quite low on wall space too (guitars, acoustic foam, etc). Do you know of any spring-loaded arms that will support the weight I need?
Thanks again
Thanks again
- bedazzled_k
