is there anything like garageband for the pc
Postby paul tha other » Tue Apr 13, 2021 1:27 pm
says it all in the title for the most part...someone i know had a serious accident and only has the use of one of her hands.she has been using garageband on her ipad but its getting old and she has a brand new pc..the important thing is the virtual instruments that garageband has..is there something like it on the pc that anyone knows of??
paul
paul tha other
http://www.myspace.com/onemanandalaptop
Re: is there anything like garageband for the pc
Postby Mike Stranks » Tue Apr 13, 2021 5:30 pm
I use Acoustica Mixcraft which I read somewhere is 'Garageband for the PC'. It certainly has Virtual Instruments, but as it's not something I'm into I don't know if it's what you're looking for...
https://acoustica.com/mixcraft
Postby James Perrett » Tue Apr 13, 2021 5:49 pm
When Garageband first came out its nearest equivalent was probably Sonic Foundry's Acid on the PC. Magix have revamped it over the last few years and there's a review at
https://www.soundonsound.com/reviews/ma ... d-pro-next
I know someone who uses it as his main DAW and gets some decent results with it.
Postby blinddrew » Tue Apr 13, 2021 9:53 pm
Might be worth looking at Cakewalk as well?
Postby paul tha other » Thu Apr 15, 2021 9:35 am
thanks for the replies guys...
she uses garageband because the virtual instruments are very intuitive and there is virtual bass, guitar and synths and keys as well as the drum thing. because she has limited movement in her hand ie she cant hold a mouse ,she uses a stylis so it needs to run on a touchscreen computer.she might be able to use a track pad on a laptop..
ill have a look at acid.i did look at mixcraft and it looks very similar to garageband
paul tha other
Postby N i g e l » Thu Apr 15, 2021 11:12 am
blinddrew wrote:Might be worth looking at Cakewalk as well?
Certainly worth a look, there are plenty of uTube tutorials & explanations [too many perhaps]. I looked at Garageband on uTube and it appeared to have quite a bit of drag and drop style content.
Cakewalk is comprehensive and free but its more about building projects up from scratch.
There are some loops & drum patterns but I cant comment on them.
The incorporated instruments include..
TTS1 general midi synth
SI string section
SI bass Guitar
SI Drum kit
SI electric pianos
as well as the usual suspect effects.
Cakewalk will of course run any 3rd party VST synths & effects you install
Postby in.name.only » Fri Apr 16, 2021 12:17 am
The free version of Waveform by Tracktion is pretty good. It has a program to generate MIDI patterns and chord progressions so could be useful for someone who only has the use of one hand. Any DAW that accepts VST plugins has a huge array of virtual instruments available. Many are free, you just need to download them.
https://www.tracktion.com/products/waveform-free
https://www.audiopluginsforfree.com
https://www.kvraudio.com/plugins/the-ne ... ee-plugins
in.name.only
Postby Stratman57 » Fri Apr 16, 2021 1:24 am
I would suggest having a look at Ableton Live. You can try it for free. It has lots of audio clips, virtual instruments, effects, both audio and MIDI and works well on touch screen PCs, especially if you're using a stylus.
Regards, Simon.
Stratman57
Postby DC-Choppah » Sat Apr 17, 2021 9:43 pm
MuLab
https://www.mutools.com/mulab-product.html
This is the a good free DAW for Windows.
This DAW can run any VST instrument and comes with many synths and instruments too.
The developer gives away the keys for the fully unlocked DAW: https://www.mutools.com/m8-temp-user-keys.html
DC-Choppah
