Bad VSTi sound again.
Postby Arpangel » Sun May 16, 2021 7:57 am
It’s back, I posted about this awhile ago, it’s really weird.
I swapped out my interface, a Behringer UMC1820, and replaced it with my Motu, which seemed to sound much better, but that awful sound is back again,
All of my VSTi's sound like they are out of phase, I placed a Reaper spectrum analyser on the VSTi track, and there is a big hump around 120k with a fall off above 6k, there are no other plug-ins anywhere, I’ve double checked.
As soon as I play some reference tracks, it all sounds fine, so it can’t be the interfaces, or the room, bedsides, it wouldn’t just go away, and come back again.
:think:
That would be an ecumenical matter.
Re: Bad VSTi sound again.
Postby blinddrew » Sun May 16, 2021 10:40 am
Ok, i know this is an anathema to your very being, but you need to take a thorough and logical approach to this and work through the options in a structured way.
Postby Wonks » Sun May 16, 2021 11:01 am
Arpangel wrote:All of my VSTi's sound like they are out of phase, I placed a Reaper spectrum analyser on the VSTi track, and there is a big hump around 120k with a fall off above 6k, there are no other plug-ins anywhere, I’ve double checked.
I assume that '120k' is meant to be 12kHz and you're not making music for bats? ;)
Postby Wonks » Sun May 16, 2021 11:02 am
What happens if you switch back to the UMC1820?
Postby Arpangel » Sun May 16, 2021 11:25 am
Wonks wrote:What happens if you switch back to the UMC1820?
I’m doing that this morning, I’ll let you know, sorry, it’s around 120 Hz the hump, it’s quite big too, makes everything sound really muddy, and the stereo is vague, like somethings out of phase. I’m coming out of the interface into my TC volume knob, then straight into my monitors, I’m not going through my mixer.
It’s highly likely I’ll go down there in minute and it’ll sound fine, all of my reference CD's sound normal to me.
I’m beginning to wonder if it’s my ears? :shocked:
Postby The Elf » Sun May 16, 2021 12:08 pm
A cheap USB isolator may be worth getting hold of. I recently had some weird frequencies that disappeared when one specific piece of gear was plugged in - one isolator later the problem was solved.
Postby Arpangel » Sun May 16, 2021 12:51 pm
The Elf wrote:A cheap USB isolator may be worth getting hold of. I recently had some weird frequencies that disappeared when one specific piece of gear was plugged in - one isolator later the problem was solved.
Thanks all, I’m off there now, I’ll try and unplug or use a different USB socket.
Postby Dave B » Sun May 16, 2021 11:22 pm
Arpangel wrote:As soon as I play some reference tracks, it all sounds fine, so it can’t be the interfaces, or the room, bedsides, it wouldn’t just go away, and come back again.
I know it's obvious, but are you playing reference tracks _through Reaper_ ? or via another app? I'd drop a reference track audio onto a stereo track in Reaper and double check something isn't going on that you're not noticing.
I'm not sure how Reaper works - is it possible that you are somehow collapsing a stereo vsti into a mono output? That might explain the slightly phasey sound.
Dave B
Postby Arpangel » Mon May 17, 2021 7:33 am
OK, it seems to vary, it wasn’t as bad yesterday as the day before.
I swapped around my USB connections, but I don’t have many, an external drive, a CD drive, wireless keyboard and mouse on my Mac, that’s it, my interface is on FireWire.
I played reference tracks on the CD drive, I’ll import some into Reaper today.
The monitoring set-up isn’t very good, I’m using Behringer Truths, one is in a corner, and I’m wondering, there is a large brick alcove behind my Mac screen, I’m wondering if that’s colouring the sound?
I turned down the bass on the monitors, and the room compensation switches, it helped a bit, but this strange character was still there, changing the interface back to the Behringer seemed to make it worse, but I’m not sure.
I think it’s about time I optimised my monitoring position, and maybe, even investing in a slightly better pair of monitors, nothing crazy, as the room isn’t treated, but at least, something a bit better than these Behringers.
I need Hugh and the team here, but on second thoughts, they’d probably run screaming if they saw my set-up!
:shocked:
Postby Aled Hughes » Mon May 17, 2021 8:19 am
The spectrum analyser wouldn’t have showed the problem if it was a problem with your ears or monitoring.
Check that Reaper’s audio isn’t reaching your interface’s output in more than one way (ie is it routed to two pair of channels in your interface’s control software, or is there a send going somewhere on the VSTi track etc)
If you save your Reaper project and upload it somewhere I’d be happy to have a look just in case there’s some strange routing going on. Perhaps also upload a screenshot of your interface’s control mixer.
Aled
Aled Hughes
www.stiwdiosain.cymru
Postby Arpangel » Mon May 17, 2021 8:59 am
Aled Hughes wrote:The spectrum analyser wouldn’t have showed the problem if it was a problem with your ears or monitoring.
Aled
Thanks Aled, the software, and interface set-up is a template I’ve used for years, it’s normally fine.
You’re absolutely right, the analyser wouldn’t show it if it was my ears, or the room.
I’ve got two sends set-up in Reaper, from the VSTi track, but they are both off, with no effects enabled.
Postby RichardT » Mon May 17, 2021 9:09 am
Try setting up a project from scratch with just one channel containing the VSTi.
RichardT
Postby Hugh Robjohns » Mon May 17, 2021 9:47 am
Arpangel wrote:I’m wondering, there is a large brick alcove behind my Mac screen, I’m wondering if that’s colouring the sound?
Highly likely.
...changing the interface back to the Behringer seemed to make it worse, but I’m not sure.
Remembering the mic/line switch debacle, There's not much help we can offer until you have a consistent and well-defined problem. Without that you'll just be chasing your tail around the room with well-meaning but ultimately unhelpful and baseless suggestions.
But since the sound is sometimes fine and sometimes not, it doesn't seem likely that the monitors are actually the problem. It's more likely to be something in your setup in the computer. So fix the real problem before you go spending money you don't need to spend on something that isn't the problem.
I'm sorry, the whole Studio SOS team are washing their hair that day.... :lol: :beamup:
Postby Arpangel » Mon May 17, 2021 10:07 am
Hugh Robjohns wrote:I'm sorry, the whole Studio SOS team are washing their hair that day.... :lol: :beamup:
I’m sorry Hugh, but that’s just not a good enough excuse………
:D :D
Postby zenguitar » Mon May 17, 2021 10:32 am
To be fair, the problem is locating the hair rather than the washing.
liberté, frivolité et vanité
