2 pieces of the same gear, different sonic signature?
Postby heavenorlasvegas » Thu Jun 03, 2021 8:38 pm
so what can influence the sonics of a piece of gear besides the circuits that make it up? especially in vintage gear...
is it rotting components?
I have 2 tandberg 12-41 reel to reel tape machines and one has a super thick, and gooey sonic print and the other not so much...
heavenorlasvegas
Re: 2 pieces of the same gear, different sonic signature?
Postby Hugh Robjohns » Thu Jun 03, 2021 8:46 pm
If you're talking magnetic tape, then bias setting, rec/rep EQ, flux level, head gap width, head alignment and, obviously, the type and quality of the tape itself will all influence the sound character quite dramatically... And then all the usual ageing electronics issues.
Postby James Perrett » Thu Jun 03, 2021 8:52 pm
In addition to the things that Hugh mentioned, how clean are the heads and have they ever been demagnetised?
Postby Folderol » Thu Jun 03, 2021 8:55 pm
Not forgetting, how much wear have the heads seen?
Postby heavenorlasvegas » Fri Jun 04, 2021 12:07 am
thanks for your replies all. the heads look pretty worn and not sure if theyve been demagnatized.
heavenorlasvegas
