Fixing dead keys on a midi keyboard
Postby JuicyLime » Mon Aug 28, 2006 12:21 pm
My Edirol PCR-30 has some keys that are intermitently not responding (ie not sending signal). It kind of feels a little like it might be just dust that has got into the circuits and action so I think I'm going to get myself some compressed air and pop it open.
Has anyone got any tips on doing this?
JuicyLime
Re: Fixing dead keys on a midi keyboard
Postby tomas » Mon Aug 28, 2006 2:27 pm
Forget the can of air, you need to get isopropyl alcohol and cotton swabs. It's the same stuff that was used to clean tape heads way back some decades ago. The usual design for the electrical contacts here is basically the same as what has been used for the buttons on calculators and TV remote controls. The buttons (keys) have a conductive and soft rubber surface that sits on a circuitboard printed with black (carbon) contact surfaces. Dirt and grime between the rubber and the carbon means bad electrical contact.
You need to take the keybed a part, so that you can get inside of the conductive rubber pads and the carbon contacts. Both surfaces should be cleaned with the alcohol.
It's not difficult, but takes some time. Putting it all back together again is probably the most complicated task...
tomas
cheers, t-:
Postby hgavin » Mon Aug 28, 2006 3:33 pm
JuicyLime wrote:My Edirol PCR-30 has some keys that are intermitently not responding (ie not sending signal). It kind of feels a little like it might be just dust that has got into the circuits and action so I think I'm going to get myself some compressed air and pop it open.
My Edirol PCR-M30 had exactly the same problem. I took the back off removed the springs and a few keys, and cleaned the contacts and the underneath of the conductive rubber strips. It wasn't difficult, but you might want to use a set of long-nosed pliers to make refitting the springs a little easier.
hgavin
Postby olafmol » Tue Aug 29, 2006 11:47 am
edirol must have some problems with their QC cause last week one key of my brand-new PCR-M30 also stopped working!
i am kind of pissed of by it, cause i almost didn't use it at all...and i don't feel like opening up the keyboard....crap
Olaf
olafmol
Postby The real musiclover » Tue Aug 29, 2006 12:24 pm
Olaf
Brand new or used, but brand new to you? No warranty?
FWIW i've seen a few of these advertised with dodgy keys.
The real musiclover
Postby XLII » Tue May 20, 2008 7:29 am
I've got one as well & key just seem to be slowly dying off. Infact, almost everyone I know used to own an edirol midi-key at some point and now when I go to their studios I see them collecting dust in the corner under a pile of junk.
thanks for the tips on cleaning. very useful.
tomas>>>
does it have to be that isopropyl alcohol or could I just use something strong? Like Smirnoff? :lol:
XLII
Postby Darclinc » Tue May 20, 2008 9:02 am
What a coincidence, my Edirol PCR-30 also stopped working like this, even though it was sealed in a box in the cupboard and hardly ever used.
I eventually gave it to my brother and bought a Yamaha electric piano, which is superb and has never given any problems.
You know, as they say, buy cheap, buy twice. Based on that philosophy I'll never buy anything by Edirol or M-Audio again, ever.
D.
Darclinc
http://www.thirdfloormusic.com
Postby ChrisCarter » Tue May 20, 2008 10:29 am
Sorry to say that the 'dead keys' symptom is a known problem with some batches of the PCR family and it's been covered in this forum (and others) quite a few times now. Roland UK (& USA?) did set up a replacement scheme a few years ago and many PCR owners simply had their keyboards replaced FOC. Unfortunately I think they no longer offer this service.
ChrisCarter
Location: Usually in the studio, sometimes on the road...
Twitter | Website | iTunes
Postby Darclinc » Tue May 20, 2008 4:29 pm
I wish I knew about that scheme ..
Ho hum, etc.
D.
Darclinc
Postby GaryW23 » Thu May 22, 2008 10:37 am
I have to occasionally take my old Roland W-30 apart to clean the key contacts, so it's not just cheap gear that suffers from this "ailment" - older gear also suffers.
GaryW23
Gary. My kit: Roland XP-30 / Alesis Micron / Korg Volca Bass / Akai S2000 / Core i3 Laptop / Roland QUAD Capture / Reaper / various plugins
Postby Prophet X » Thu Jun 19, 2008 9:29 pm
Likewise. My Z1's just lost note on/off to the middle E key, though aftertouch is still being transmitted. Fortunately I've already had the experience of dismantling & rebuilding an X3, so it shouldn't be too bad - when I decide to take the plunge! It's just a case of unscrewing the baseplate & taking out a few circuit boards & the keybed itself - and making sure that you have the space to keep all the components organised!
Prophet X
Postby Interweaved » Thu Jun 19, 2008 10:32 pm
Don't use isopropyl (rubbing) alcohol.. I've heard this weakens plastics.
Anyhow, use a silicon cleaner for circuits or switches like one of these (these sources from google):
http://www.crcind.com.au/catalogue.nsf/web_brands/Switch+Cleaner+Lubricant?openDocument
http://www.moldsprays.com/405_contact_circuit_01.htm
In fact, the stuff you use to clean a car distributor might be fine. Check the can.
Interweaved
Postby ainternational » Mon Sep 28, 2009 11:23 am
GaryW23 wrote:I have to occasionally take my old Roland W-30 apart to clean the key contacts, so it's not just cheap gear that suffers from this "ailment" - older gear also suffers.
Is this a difficult job? I use my old W30 as a master keyboard and a couple of keys have stopped working: been working around this for some time, which says a lot about my 'skills' as a player, but would like to fix it. Can anyone point me in the right direction of some instructions as to what to unscrew and what to beware of? Would Caig DeOxit work as a cleaner? It seems to work wonders on most things...
PS: Think I've just found answers to these questions here
http://www.milton.arachsys.com/nj71/index.php?menu=2&submenu=4&subsubmenu=2&page=10
That looks to contain all I need to know - excellent resource.
ainternational
Postby desmond » Mon Sep 28, 2009 12:04 pm
Interesting - I have a Studiologik piano-type hammer-action master keyboard I recently got down out of the roof, to find a cluster of black notes in the middle have a dodgy velocity response (ie, soft presses don't register a note - they start triggering at about a strength/velocity level of 40-50 or so.
I'v taken it apart and checked for obvious stuff (cleaned out dust etc) but the problem persists, so I'll need to get a little more "cleaney" on the key contacts next time...
Postby adrian_k » Tue Sep 29, 2009 11:32 am
ChrisCarter wrote:Sorry to say that the 'dead keys' symptom is a known problem with some batches of the PCR family and it's been covered in this forum (and others) quite a few times now. Roland UK (& USA?) did set up a replacement scheme a few years ago and many PCR owners simply had their keyboards replaced FOC. Unfortunately I think they no longer offer this service.
Yep, I got mine swapped in January this year, might be worth a try. The keyboard was 3 years old...
adrian_k
getting better all the time..
