Small bass drum module...
PostPosted: Mon Feb 15, 2010 5:43 pm
by Hewesy
Hi,
I'd like to build a small electronic bass drum module, for self accompanying acoustic guitar. I've used a few footstompers, including the really cool Logarythmn, but they only seem to work at stage levels or through a good PA/bass amp.
What I'd like to do is build a small bass drum module, which I can trigger via a footswitch (like a Yamaha FC5). I know I can use a drum machine for this, but ideally I'd like something smaller to sit on my pedalboard.
Help! I'm happy to tinker and build something (as long as it is not overly complex).
Hewesy
Re: Small bass drum module...
PostPosted: Wed Feb 17, 2010 11:45 am
by Spiked Lunch
Just a thought but how about using/modifying a modular synthesizer bass drum module such as the MFB DRUM-04 => http://www.mfberlin.de/Produkte/Module/DRUM-04/DRUM-04e/drum-04e.html
You should be able to trigger it using a cheep on/off type sustain foot switch in series with a battery to create a DC pulse.
If you wanted to, you could probably do a basic repetitive sequence by building a square wave LFO.
I imagine that you could probably rehouse it into something more guitar pedal like if you wanted, only showing the controls you need.
The only issue may be the power supply - probably similar, if not the same as for the Doepfer modules.
Mike
PostPosted: Thu Feb 18, 2010 9:55 am
by Hewesy
Now that does look cool, and I like the options available to.
Thanks Mike, I'll put that as the Rolls Royce solution, but very nice indeed...
Hewesy
PostPosted: Tue Feb 23, 2010 1:25 am
by artifus
PostPosted: Wed Feb 24, 2010 9:47 am
by Hewesy
Now they look very cool, thanks! Have you made any of them?
Hewesy
