laptop recording
laptop recording
PostPosted: Thu Feb 25, 2010 12:52 am
by MiasmaGasma
although i have used digital multitrack machines and have used acid on my pc for several years i am quite unsure what to do next.
i want to spend less than £400 ( absolute upper case limit ) on a laptop but i am intending on using it a lot for recording through microphones and direct from instruments.
what factors should i be taking into consideration?
soundcard?
processor?
Re: laptop recording
PostPosted: Thu Feb 25, 2010 11:12 am
by ConcertinaChap
The onboard audio won't be up to the job, so you're going to need an external interface. Is that included in your £400? If it is then you're cutting things awfully tight!
Chris
