Resampling
Resampling
Postby Anonymous » Wed Apr 28, 2010 3:32 am
Why and when do people use resampling?
Anonymous
Re: Resampling
Postby desmond » Wed Apr 28, 2010 3:58 am
In what context?
Re: Resampling
Postby Dave B » Wed Apr 28, 2010 1:25 pm
Re-sampling is like 'freeze' on tracks for DAWs. It's about combining a more complex sound into a single sample to conserve resources.
Dave B
Re: Resampling
Postby GaryM » Wed Apr 28, 2010 1:28 pm
I thought re-sampling was what you did when you wanted to change the sample rate of some digital audio. Never knew it was also the term for bouncing down a group of tracks.
GaryM
Re: Resampling
Postby Dave B » Wed Apr 28, 2010 1:29 pm
Ah could be - I'm old school so to me 'resampling' is what you did on an Emulator II or EPS16+ ...
:bouncy:
Dave B
Re: Resampling
Postby planetnine » Wed Apr 28, 2010 1:37 pm
Dave B wrote:Ah could be - I'm old school so to me 'resampling' is what you did on an Emulator II or EPS16+ ...
:bouncy:
I would have called that rendering.
planetnine
Planet Nine, Lincoln, UK.
Re: Resampling
Postby desmond » Wed Apr 28, 2010 1:45 pm
Which is all why I asked to what context the OP was referring, so we knew what he was referring to.
Re: Resampling
Postby Guest » Wed Apr 28, 2010 3:39 pm
desmond wrote:In what context?
In the context of changing the sampling rate.
Guest
Re: Resampling
Postby desmond » Wed Apr 28, 2010 3:43 pm
Re: Resampling
Postby Hugh Robjohns » Wed Apr 28, 2010 4:28 pm
Music Manic wrote:In the context of changing the sampling rate.
You sample rate convert material when it is at a different sample rate to the rate you want to work at, or when it is at the same rate but running asynchronously.
Many plug-in effects processors sample rate convert in order to enhance the precision of the processing, most up-sampling to a double rate and then down-sampling again afterwards to the native rate of the DAW session.
Some ADCs and DACs use SRCs as part of their jitter isolation process, performing the actual domain conversion to a locally generated clock and using the SRC to convert the signal to or from the external rate.
Hugh
