Easy to Use DAW
Easy to Use DAW
Postby tallboss » Fri Aug 06, 2010 9:49 pm
Hi Guys
I record on a Zoom MRS8, and want to link up to a D.A.W. I know this can be done.
Can anyone give some recommendations of a good, easy to use, and on the cheaper end, DAW?
Thank you :beamup:
tallboss
Re: Easy to Use DAW
Postby grab » Fri Aug 06, 2010 11:03 pm
Cheapest with full functionality is probably Reaper - free if you don't get a license. (Which would be naughty if you're using it much, but possible.) Or Audacity, but Audacity's support for VSTs ain't great and it's generally not very friendly - it's really a wave editor, not a DAW.
For easy-to-use, Mixcraft is very easy to us and relatively cheap, but it doesn't have the features that Reaper does.
grab
Re: Easy to Use DAW *DELETED*
Postby FaceTheMusic » Sat Aug 07, 2010 1:19 am
Post deleted by zenguitar
FaceTheMusic
Re: Easy to Use DAW
Postby GaryM » Sat Aug 07, 2010 3:08 am
FaceTheMusic wrote:post deleted by zenguitar
:shock:
GaryM
Re: Easy to Use DAW
Postby ef37a » Sat Aug 07, 2010 9:03 am
Err?
Almost "All things that can be used as an Audio Interface" come with some sort of software, most commonly Cubase LE.
The Zoom may not come with any but a look at their website might be profitable?
Re: Easy to Use DAW
Postby Mike Stranks » Sat Aug 07, 2010 10:13 am
MAC or PC?
Garageband is s'posed to be simple and good for MAC and, seconding Grab, Mixcraft 5 is getting some good reviews for PC-based stuff. Some say it's the PC equivalent of Garageband.
HTH.
Re: Easy to Use DAW
Postby tallboss » Sat Aug 07, 2010 12:40 pm
Hi Guys, thanks for your suggestions. Reaper and Mixcraft keep coming up.
I am trying Reaper at the moment, it does have everything - but easy to use??!!
I'll try out Mixcraft :bouncy:
tallboss
Re: Easy to Use DAW
Postby tallboss » Mon Aug 09, 2010 4:21 am
Thanks guys - it looks like Mixcraft wins the day. Easy to use, and very logical to use! It does what I want it to do, the way I want to do it!
Thanks for the help and suggestions :bouncy:
tallboss
