Would you like your track remixed by SOS?
Re: Would you like your track remixed by SOS?
Postby Zukan » Sun Sep 10, 2017 10:49 am
blinddrew wrote:Working on some stuff at the moment but not ready yet! :)
Well, get your act together...sigh.....
Zukan
Postby blinddrew » Sun Sep 10, 2017 10:58 am
Literally working on it right now!
Postby The Korff » Thu Sep 21, 2017 9:54 am
Not at all — in fact, most of the tracks we work on are; that's what gives the column its 'rescue' name (though they're not all salvage jobs, by any means). The idea is to show people how a mix can be improved, but it's not an audio-editing or auto-tuning workshop, so ideally it'd be a musically competent track whose mix is letting it down, if you see what I mean.
Cheers,
Chris
The Korff
Postby Matt Houghton » Thu Sep 21, 2017 10:36 am
Yeah, the column started out that way, and we're still very happy to take on amateur projects. Though of course we reserve the right to suggest that you go back and try to re-record certain sections if the salvage job looks too daunting ;)
The Mix Rescue column is now a mix of those sort of projects, and of more straight-forward mix jobs (those written by Neil Rogers generally fall into the latter category). The reason we added those is that we felt that the column had been giving the impression that you *should* be doing all of this corrective stuff in the mix stage, whereas in reality, on commercial projects many such problems would have been avoided further upstream, at the recording/programming/arranging stage. It's great that plug-ins can help you problem-solve such things, but we wanted also to give an impression of what mixing *should* be about when those first parts go as they should in the first place!
I'm also keen to add a few remix features under this guise — where someone does something like a dance remix of a rock or pop tune and writes up their approach, so candidates for that are welcome too. Just be clear about that when you write in.
Cheers,
Matt
mixrescue@soundonsound.com
Matt Houghton
SOS Reviews Editor
Postby Zukan » Thu Sep 21, 2017 1:17 pm
You know Matt, now would be a good time to relaunch the Fiona Joy New Age stems remix project. I have all the stems and necessary info, and of course, all permissions in place.
Zukan
Postby blinddrew » Sat Aug 25, 2018 12:49 pm
Completely forgot about this thread!
I have actually finished a couple of things over the last year, and whilst I don't think they need a full-on mix rescue (you may disagree), I'm more than happy for people to have a play at remixes or sampling from them.
Solo EP: https://drewstephenson.bandcamp.com/alb ... land-sound
Solo single: https://drewstephenson.bandcamp.com/track/road-song
Band EP: https://thesouthernwild.bandcamp.com/al ... lost-roads
If any of that's of interest to anyone (not just Zukan :P) I can provide stems as required.
None of it is professionally recorded or mixed so it's probably more suited to practice material or some heavy sonic mangling, but if anything is of interest just shout.
Postby Argiletonne » Mon Aug 27, 2018 10:43 pm
Remixed. How about de-remixed. Take what's there and make less of. The remix scene is growing old now that everything is made on the computer and most new school music producers use lots of automation and endless amounts of processing.
Argiletonne
Postby blinddrew » Tue Aug 28, 2018 9:54 pm
remix, demix, unmix - more than happy for anyone to play around with any of it however they like. :)
Postby Zukan » Sun Sep 30, 2018 12:39 pm
Blind, send me some stems pal.
Zukan
Postby blinddrew » Sun Sep 30, 2018 12:47 pm
Will dropbox some stuff up this arvo.
Postby blinddrew » Sun Sep 30, 2018 4:19 pm
Now then Zukan (and anyone else playing along), here's a few stems from three fairly different tracks:
Road song stems: https://www.dropbox.com/sh/9cdyst4y6363 ... bnCha?dl=0
The Storm Keep stems: https://www.dropbox.com/sh/vye856lrdth2 ... j6WWa?dl=0
Words stems: https://www.dropbox.com/sh/xnwaidzd9vj3 ... d1Ipa?dl=0
Play with them as much or as little as you like and just shout if there's anything else you'd like. :)
