Tackling room resonances
Re: Tackling room resonances
Postby Eddy Deegan » Sun Jul 28, 2019 8:06 pm
TNGator wrote:... does the rockwool have to be of a certain grade or thickness etc. Builders sell this for the purpose of insulating a house. They're not in the home studio business. Can any rockwool work?
Not all rockwool is equal. You need to find the right rockwool density for audio use. I can't reel off the right specs from the top of my head but my understanding is that you can get the correct grade from a builders merchant, though you may need to have them order it or hunt around a bit.
Hopefully someone more knowledgable than I can give you the info you need, else I'll dig it out from my notes later when I get home.
Some of my works.
Postby blinddrew » Sun Jul 28, 2019 8:12 pm
Not sure if you use the same specification over there but what you're after is RW3, 45 - 60kg/m3 is the density you want to be looking for.
Or at least I hope it is because it's on my shopping list... :)
Postby TNGator » Sun Jul 28, 2019 8:52 pm
blinddrew wrote:Not sure if you use the same specification over there but what you're after is RW3, 45 - 60kg/m3 is the density you want to be looking for.
Tá. You know in hindsight my question ws a bit silly in that there probably isn't a great selection. It might be a case of you'll take what you're given. But thanks Bro... At least I can keep an eye out for those specs.
TNGator
Southern kin y'all
Postby James Perrett » Sun Jul 28, 2019 9:03 pm
Rockwool RW3 or Rocksil RS60 are the most popular ones. For some purposes you can go for lower density like Rockwool RWA45 and for others you might want a higher density like RS100 but for panels the 60kg/m3 density seems to be the best compromise. If you can mount them so that they are spaced slightly away from the wall they become effective down to a slightly lower frequency.
Postby Sam Spoons » Sun Jul 28, 2019 10:16 pm
Or for corner traps, a stack of triangular pieces filling the corner with a 12"-18" front face are even more effective ('cos the cut edges are more absorbent than the treated faces and 'cos the effective depth is greater).
Postby Mike Stranks » Sun Jul 28, 2019 10:20 pm
Sam Spoons wrote:Or for corner traps, a stack of triangular pieces filling the corner with a 12"-18" front face are even more effective ('cos the cut edges are more absorbent than the treated faces and 'cos the effective depth is greater).
Yup! As taught to me by Studio Support Gnome!
Postby Wonks » Sun Jul 28, 2019 10:25 pm
If you struggle to get rockwool of a suitable density, glass fiber is far more widely used in the US for bass and broadband traps than in the UK. Similar issues with loose fibers causing irritation and similar remedies utilised, but the absorption performance is comparable. (US spelling of 'fibre' used).
Postby Sam Spoons » Sun Jul 28, 2019 10:28 pm
Me too, SSC's, or to give them their full title "Studiotips Super Chunks". :thumbup:
Glass fibre is not as kind to your body as Rockwool mineral fibre (it's more likely to cause irritation and so on) but no reason why it should be less effective AFAIK.
Postby Eddy Deegan » Mon Jul 29, 2019 2:59 am
blinddrew wrote:what you're after is RW3, 45 - 60kg/m3 is the density you want to be looking for. Or at least I hope it is because it's on my shopping list... :)
James Perrett wrote: for panels the 60kg/m3 density seems to be the best compromise. If you can mount them so that they are spaced slightly away from the wall they become effective down to a slightly lower frequency.
Checking my notes, Max was of similar opinion - 60kg/m3 was the magic number, at least in my case. Of the five bass traps in the plan he formulated for me, 3 are spaced from the wall and 2 are thick enough (due to a good window indent depth) to not need it.
Some of my works.
Postby Martin Walker » Mon Jul 29, 2019 12:21 pm
+1 for 60Kg/m3
After installing half a dozen RealTraps after reviewing them for SOS years back, I still needed more trapping, so I bought some 45Kg/m3 rockwool that I assembled into 4' by 2' by 1' megachunks, sprayed with the recommended dilute PVA adhesive (to stop the fibres shedding), and then simply wrapped them in butter muslin.
They made a very real difference, but have sagged a bit since. Mine were all floor-mounted, so if you're considering wall-mounted traps then 60Kg/m3 makes a lot more sense.
Postby Wonks » Mon Jul 29, 2019 12:53 pm
*kg/m³
Postby TNGator » Mon Jul 29, 2019 1:32 pm
Martin Walker wrote:+1 for 60Kg/m3
Hi Martin
I have a roll of what i believe is mineral wool. Well not a full roll but darn close. It was left over from building work we had done a few years back. Its too expensive to simply dump so I mailed the manufacturer to ask what it was and explained what I need it for. They replied after a while and said they wouldnt recommend for sound treatment and sent a link for some other stuff but Id need to order it online. So I might have to simply buy those rock wool slabs or got to Thomann who do a good range of actual sound treatment products. You know if my test mic would just get here soon I could test what i have using the REW software.
oh....quick question guys. Theres a builder doing work next door. Nice lad from England so i was talking to him just now about what Im at. He wasnt sure of course about sound treatment but....as far as making a light weight frame was concerned he showed me the aluminum studding they use now. Weighs nothing. But would an aluminum frame on your absorber defeat the purpose due to reflections? I could probably cover the frame with fabric. I dont have a pic but I could probably send one.
TNGator
Southern kin y'all
Postby TNGator » Mon Jul 29, 2019 1:33 pm
Hi Martin
Ah...the rockwool Im looking at here is only 38K. Too light? If I used two slabs does that double it up? https://www.goodwins.ie/products/Rockwo ... filter_set[]=1413,1451
TNGator
Southern kin y'all
Postby Hugh Robjohns » Mon Jul 29, 2019 2:12 pm
TNGator wrote:But would an aluminum frame on your absorber defeat the purpose due to reflections?
Not as long as you're talking thin metal corner pieces and struts, or panels with a lot of holes/slots in it. Most of the commercial traps use metal framing, such as these Realtraps MiniTrap panels:
Postby TNGator » Mon Jul 29, 2019 2:44 pm
Yes very similar to the pic Hugh. Apparently builders are using these now instead of 2x4 studs. They have a mesh type design. Some spray paint and you could have something very cool n trendy lie the ones you've shown here. .
TNGator
Southern kin y'all
