Tackling room resonances
Page 1 of 8
PostPosted: Sun Apr 30, 2017 5:06 pm
by The_Doorman
I'm all set up to start mixing songs in my new studio (room). You can see a couple of pictures at www.doormanmusic.com/studio. Using the excellent book "Mixing secrets for the small studio" of Mike Senior I first started treating the room a bit. In every corner I put a bass trap/absorber of 104 x 64 x 10 cm made of Rockwool 221. I put pieces of DAP-Audio ASM-03 acoustic foam (50 x 50 x 10 cm) behind every Genelec 8020 speaker and 1 at each reflection point. Only 1, maybe a bit too little?
So, while testing both the Genelec's and an Avantone Mixcube with the LFSineTones audio file mentioned in the book all seems well until frequencies of 92, 111, 147, 165, 185, 233 and 262Hz kick in. Especially the latter five are really louder.
What could I do additionally in treating the room? I mounted the bass traps halfway in each corner and considering a low ceiling at 2,2m with beams it's difficult to mount more. Does placing more acoustic foam help? Any helpful suggestions are really appreciated! :thumbup:
Re: Tackling room resonances
PostPosted: Sun Apr 30, 2017 11:09 pm
More bass trapping is really the only way. Placing bass traps in the tri-corners where two walls meet the ceiling is the most efficient and effective location, bu running theme full height of the wall-wall corners is the next best option.
Bass has long wavelengths so the absorbers need to be deep. An inch o two of foam won't help...
PostPosted: Mon May 01, 2017 6:14 am
by Bob Bickerton
If you have the budget and are serious about it, you could have your room analysed by an acoustician and have a bespoke treatment plan designed.
If you're handy, you could then make and hang acoustic panels to implement the design.
PostPosted: Tue May 02, 2017 11:26 am
by James Perrett
Looking at your pictures I see lots of bare walls - you need more guitars on them :bouncy:
If you can't have more guitars then maybe put some tall bookshelves along the back wall to break up the reflections. I'd also follow Hugh's recommendation for more bass trapping - there are plenty of spaces for it.
PostPosted: Wed May 03, 2017 4:41 pm
by The_Doorman
I'm a bit at a loss here... :headbang: :SOS: I bought two Auralex LENRD bass traps and decided to run some tests using REW (Room EQ wizard) and micing the output of my Genelec speakers at the mixing position. Placing the traps in two of any of the 4 wall-wall-ceiling corners did not improve anything in the spectrum of 30-300 Hz. Even worse, dismounting the previously placed bass traps that you could see in the pictures (Rockwool 221=55 kg/m3, 4"), also did not make a big difference! You can see the latter plots (for the left and right speaker, respectively) at www.doormanmusic.com/studio. I also uploaded a picture of the lay-out of my studio where you can see the dimensions, my mixing position and the only wall, which is concrete, indicated. The other three walls are drywall consisting of double layers of Rockwool 211=45 kg/m3 with plasterboard at the exterior.
I already invested a couple of hundreds but feel I'm not making any progress here. Could the beams protruding from the ceiling be the main culprit? Should I confine acoustic treatment more to the mixing position?, as in this example: http://www.soundonsound.com/techniques/studio-sos-michael-harvey
Again, your help is very much appreciated! :clap:
PostPosted: Wed May 03, 2017 5:09 pm
The_Doorman wrote:I'm a bit at a loss here... :headbang: :SOS: I bought two Auralex LENRD bass traps and decided to run some tests using REW (Room EQ wizard) and micing the output of my Genelec speakers at the mixing position. Placing the traps in two of any of the 4 wall-wall-ceiling corners did not improve anything in the spectrum of 30-300 Hz. Even worse, dismounting the previously placed bass traps that you could see in the pictures (Rockwool 221=55 kg/m3, 4"), also did not make a big difference!
I'm not really surprised. Effective bass trapping is a real challenge and it takes a lot of big bass traps to have a worthwhile effect. A couple of small foam wedges won't do anything useful at all. Most panels sold as 'bass traps' are nothing of the sort -- they're midband or broadband absorbers at best.
Here's an example of a professionally treated room to give you an idea of what's typically needed. The top red trace shows the RT measurement from the bare room, while the bottom blue trace is with most of the standard acoustic panels installed -- big improvement but still a wayward low bass. The purple trace is with the large white bass-trap panels installed as you can see in the second photo (there were more of those across the back wall too)
PostPosted: Thu May 04, 2017 10:24 am
by James Perrett
In my last studio I had modular bass traps covering almost the whole back wall as well as treatment over most of the rest of the room. In my current studio I have floor to ceiling corner traps in 3 corners (will be 4 when I get round to finishing it) and also between the wall and ceiling along the whole wall behind the speakers.
PostPosted: Thu May 04, 2017 10:46 am
by The_Doorman
OK, thanks. Considering a current tight budget (earlier, I had to spend 15k at making the basement waterproof) what would be my best bet (to get a reasonable bass reduction)? In order of importance would it be (based on your suggestions)?:
1) e.g. Primacoustic Cumulus Tri Corner Bass Traps in each of the 4 tri-corners
or:
2) Primacoustic Maxtraps in the wall-wall positions replacing the current Rockwool 221 panels
I mention Primacoustic with regard to availability in the Netherlands (GIK, Realtraps would also have to be imported).
Regarding budget I could realize option 1 but option 2, for now, only at two places. So, in front or in the back of the mixing position?
I could then glue the DAP foam onto the Rockwool 221 panels and place them at the reflection points.
PostPosted: Thu May 04, 2017 12:34 pm
by James Perrett
The best way to do this on a budget is to forget about buying commercial products and build your own panels from Rockwool slabs in a wood frame covered by Cara fabric.
PostPosted: Thu May 04, 2017 12:54 pm
by The_Doorman
Do own 'Recording secrets'and 'Mixing secrets' but did not know about The Studio SOS book :thumbup: (found it after googling your final sentence!). This can be really helpful and indeed a starting point to construct the traps myself.
PostPosted: Sun Jun 04, 2017 12:54 pm
by The_Doorman
OK, here's what I did so far:
1) Rotating the mixing position 90 degrees so that it's now along the length of the room and at equal distances from left and right walls gave a huge improvement in bass resonances / modal ringing. Mixing position is at 28% of the length of the room. Not near 38% but at a maximum aesthetically acceptable position ;)
2) I now placed the black Rockwool 221 traps on top of each other in the back wall corners, extending from top to almost the ceiling (but the tricorner is shielded by several ceiling beams when viewed from the mixing position - see pictures at www.doormanmusic.com/studio.
3).... and placed loft insulation rolls according to several suggestions amongst which http://www.soundonsound.com/techniques/studio-sos-stourbridge-community-centre in the front corners. These are PE wrapped mineral wool rolls, brand Knauf Expert with Rd value 4,55 (don't know exact density). They fitted perfectly from floor to ceiling and gave a notable improvement when looking at the waterfall plots (see my URL).
The current waterfall graphs are consistent with a resonance at 65-70Hz (using Mike Senior's LFSineTones audio file) trembling the desk and an audible peak at ~98Hz.
My questions:
1. what do you think of the current waterfall plots?
2. when can bass trapping be considered good enough for decent mixing results, considering this studio set-up?
3. what could I do more to improve it?
The back wall (where, btw, I will mount guitars as usable diffusers) is concrete and at more than 5 m distance. The other walls are plasterboard. Loft insulation in the front corners gave a better effect than in the back corners.
4. are the corners near the mixing position more important to treat regarding bass build-up, irrespective of the composition of the wall?
5. I can assume that the windows at the front will transmit the bass?
Your help and feedback is again greatly appreciated!
PostPosted: Sun Jun 04, 2017 1:04 pm
by Tim Gillett
Dont know if it's been covered but the speakers' interaction with a desk can add a nasty peak in the region you mentioned. Is this a possible issue?
PostPosted: Fri Jun 09, 2017 4:14 pm
by Dr Huge Longjohns
You could put some more rolls along the floor to wall junction under the window for starters.
What are your speakers sitting on? You can get all sorts of funny business going on if they're on hollow boxes or something?
PostPosted: Sat Jun 10, 2017 9:05 am
by The_Doorman
Last week I got even better results. In the end the rolls are at the back and the panels at the front. Also moved the monitoring position slightly. Now I'm left with ringing at 60Hz according to the waterfall graph. I'm gonna live with that.
I've got two rolls left so I will put them at the floor to wall junction like you said. The desk resonance is pretty much gone, it turned out to be loose items trembling. My speakers are on styrofoam boxes completely filled with sand, so they're pretty solid.
PostPosted: Sun Jul 28, 2019 6:09 pm
by TNGator
James Perrett wrote:The best way to do this on a budget is to forget about buying commercial products and build your own panels from Rockwool slabs in a wood frame covered by Cara fabric.
guys I know this discussion is quite old but Im trying to sort out my room and as such am going through the previous posts and queries relating to room treatment etc. I found a build supplier here in Dublin near my home who has rockwool in easy to use slabs in a pack. Sounds easier to use than a roll of the stuff. But does the rockwool have to be of a certain grade or thickness etc. Builders sell this for the purpose of insulating a house. They're not in the home studio business. Can any rockwool work?
Xave
