Any ideas?
Sir Hannes wrote:Heard about that before. Thanks for your posting still.
Just imagine, I create an EQ-track with 8x eq's in the slots. I have this duplicated with all plugins for stereo objects. Now: how can I get an object, let's say a mono audio file from a car passing by with automation, to that dedicated mono EQ track. Between these are 80 FX tracks. This should be done via one key press (e.g. Eucon or MaestroKeys). And it must be in sync, no smallest ms/frame to the left or right is allowed. I could make this manually via mouse drag&drop and scrolling, or cmd+x and scrolling down via cursor, but this in not an option with so many tracks as it takes extremely too much time.
And if I would put this tracks near the tracks I am working on? - not useful, when I have to remix elements between 80 tracks.
I guess here it ends?
No, it can't do that. Only as an insert. I already asked the company.Sam Inglis wrote:I wonder if Softube's Console 1 works as an AudioSuite plug-in/controller? I never thought to try it that way. If so then it would be good for your needs I think.
Sir Hannes wrote:Thanks for reply your idea. I tried to follow yours but I guess, this is more for music than 1000 of audio objects, when each object is around say 10sec, then on the same track followed by others which needs completely different (!) EQ settings.
And - if I understand you correctly - I would create 80 audio objects with a length of 90min (feature film). So this would kill my HD, as for one object I maybe need 8 times of processing with different plugins.
Did I get you right?
Users browsing this forum: Martin Walker
