What is better for mixing between Cubase, Protools & Logic?
Postby Andre PW » Wed Apr 11, 2018 12:34 pm
I just started recording my own music a year and a half ago, i used to have engineers work for me that would use Protools or Logic but i recently acquired Cubase from a Friend. I mainly need it only for voice recordings. let me know what you all think is best! thank you very much
Andre PW
Re: What is better for mixing between Cubase, Protools & Logic?
Postby desmond » Wed Apr 11, 2018 1:23 pm
There is no best, and all are broadly comparable, and only differ in minor ways.
Postby ConcertinaChap » Wed Apr 11, 2018 3:11 pm
If I was in your situation since you've already got Cubase I'd just try it and see how I got on. N.B. I've never used Cubase myself but it's pretty obvious all the main DAWs are broadly comparable because if they weren't and there was one obviously better DAW then the others would fall by the wayside.
Welcome to the forum, BTW.
ConcertinaChap
Disclaimer: I don't claim to know anything at all.
Postby Sam Spoons » Wed Apr 11, 2018 3:30 pm
Have you any experience of any of them yourself? As has been said, they all do the same stuff and the differences are in the user interface. If you have used, say, Cubase for a while then stick with it as changing to another will require learning a new way of working. If you haven't then choosing one your friends use gives you access to some help an assistance when you need it.
Postby The Elf » Wed Apr 11, 2018 10:26 pm
There are still some odd stalwarts out there that believe you need Pro Tools (and/or Logic) for 'Pro' mixes. It's nonsense.
If you have Cubase, and you know/like it, then it will do the job perfectly.
Postby SoundComet » Thu Apr 12, 2018 3:39 pm
They all offer really good platforms to mix but at our studio all my engineers prefer Logic Pro because we find that the quality of the effects are slightly better. If I had to choose in order I would say:
1.Logic
2.Pro Tools
3.Cubase
Good Luck with your project :)
Milad Darani
Owner of Sound Comet
milad@soundcomet.ca
http://www.soundcomet.ca
SoundComet
Postby Martin Walker » Thu Apr 12, 2018 4:54 pm
HI Milad, and welcome to the SOS Forums! 8-)
I'm slightly surprised that you would choose a DAW because of the relative quality of its bundled plug-in effects.
I thought most DAWs provide good quality effects nowadays, and few professionals seem to rely on the bundled ones anyway, preferring to amass a specific collection that works for them.
Having said that, Logic does come highly recommended by a lot of musicians, so perhaps it's horses for courses ;)
Postby SoundComet » Thu Apr 12, 2018 8:12 pm
Thanks Martin , I know on paper they are pretty much the same thing, but I tend to get marginally better results with logic, specially with its space and delay designers. Definitely horses for courses haha.
Milad Darani
milad@soundcomet.ca
http://www.soundcomet.ca.
SoundComet
Postby Martin Walker » Fri Apr 13, 2018 7:53 pm
Fair enough Milad :thumbup:
If that's what works for you, then great ;)
Postby OneWorld » Sat Apr 14, 2018 5:25 pm
The Elf wrote:There are still some odd stalwarts out there that believe you need Pro Tools (and/or Logic) for 'Pro' mixes. It's nonsense.
What I like about Cubase is the Render in Place facility. I use some hardware synths so record the out and put everything into wav and I find the mixing in Cubase easier to get along with i the later versions and was amazed that Render in Place has as good as done a perfect job of rendering down to stereo.
OneWorld
Postby SafeandSound Mastering » Sun Apr 15, 2018 3:28 pm
Anyone who can hear well enough to be a professional mix engineer will very quickly hear that select third party plugs ins are superior than anything included in any specific DAW.
There are possibly 1 or 2 exceptions per DAW but nothing that will make or break your mix with a third party equivalent. (often in fact superior)
You mention mainly recording voices but also mention mixing in the title. The most important criteria is stabilty on your computer. That you will only find out about by using and as you have Cubase now it makes sense to investigate by trying it out.
Whatever you use, ensure your session/project is set to record at 24 bit resolution and leave decent headroom below 0dBFS on the loudest sections of any vocal recrodings.
Postby ConcertinaChap » Sun Apr 15, 2018 8:40 pm
SafeandSound Mastering wrote:AWhatever you use, ensure your session/project is set to record at 24 bit resolution and leave decent headroom below 0dBFS on the loudest sections of any vocal recordings.
That's cracking good advice.
ConcertinaChap
Postby The Elf » Mon Apr 16, 2018 8:21 am
I'd go as far as to say to ensure that *no* recording peaks above -10dBFS, vocals or anything else. then ansure that you preserve these peak levels throughout every stage of the processing chain. Not only will mixing be much easier, but you won't be having to re-trim to prevent overloading the mix buss.
Postby Cave Studio » Wed Apr 18, 2018 2:04 pm
The speed of work is down to which workflow you prefer. The sounds depends on your use of stock plugins.
Cave Studio
Postby rapitfiya » Sun May 06, 2018 5:19 am
I've gone through many a DAW in my day (Cubase, Ableton Live, Logic, Sonar, ProTools), but currently I'm sticking with Logic Pro X (heck, I learned from the guy that wrote the book back in '04, before they revamped it). I really like the way they've made it look so simplistic and intuitive yet it has all the major tools you could ask for.
Although I've been out of the loop so long that I"m back on here looking for good working and mixing techniques. Anyone here, please point me in the right direction if you know of a good article or document? Thanks
rapitfiya
Postby CS70 » Sun May 06, 2018 4:49 pm
rapitfiya wrote:I've gone through many a DAW in my day (Cubase, Ableton Live, Logic, Sonar, ProTools), but currently I'm sticking with Logic Pro X (heck, I learned from the guy that wrote the book back in '04, before they revamped it). I really like the way they've made it look so simplistic and intuitive yet it has all the major tools you could ask for.
"simplistic and intuitve" is just what you know or are used to. :) That is, of course, an excellent reason to stick with a software.
Are you thinking of working and mixing techniques in general, or specifically for Logic?
Postby Hugh Robjohns » Sun May 06, 2018 5:48 pm
Andre PW wrote:let me know what you all think is best! thank you very much
The 'best' one is the one you know how to use!
They all do the same things and if its just for voice recording and editing you won't be worried about their MIDI handling, or bundled instruments. Pro Tools is expensive. cubase less so, and Logic comes with a lot of plugins and virtual instruments but only works on a Mac.
If you've got a legit copy of Cubase to hand I'd say learn to use that.... But there are plenty of alternatives if you don't get on with it.
Postby Hugh Robjohns » Sun May 06, 2018 5:57 pm
The Elf wrote:...but you won't be having to re-trim to prevent overloading the mix buss.
A pedantic but important point if I may, Mr Elf? You can't overload the mix bus in a (floating point) DAW. But what you can do is overload the physical outputs, and potentially any modelled plugins -- so maintaining sensible headroom and gain structures is essential, just as it is/was in the analogue world.
I agree that a good target is to have nothing peak over -10dBFS when tracking, and more than -6dBFS when mixing... And if it was 5-6dB lower in both cases it wouldn't hurt!
Postby ConcertinaChap » Mon May 07, 2018 7:12 am
@Andre PW .... so, having read the above what do you think now?
ConcertinaChap
Postby Bisturi » Wed May 09, 2018 12:27 pm
Hi I don't really think there is a uber-alles DAW, I just think that there is the perfect DAW for the right job.
I mean, you could use Live to record a live band but that's simply not ideal because you have a lot more options in other DAW for this job.
So it is more up to you than the DAW ;)
Bisturi
