Sonarworks measure problem.
Postby The Sponge » Tue May 15, 2018 8:22 am
Hi All.
I have a curious issue trying to do a new measurement using Sonarwork measure software and an Audient Id4 interface.after selecting the id4 as the input device in the software, I have no input signal coming in butt the signal is present in the id4 as I can hear it clearly by turning the monitor mix knob to input and using headphones. The interface is also working perfectly when I have my Daw open.
I have set the sound settings for both the input and output of the device to 16bit 44.1 as is recommended and have tried various buffer size settings.
I have uninstalled the software, cleaned the registry etc and re installed & still nothing.
my last measurement was taken with a Alesis ios 2 interface that is long gone, and that was a very simple process, but I have some new Focal Alpha 65s that I would like to hear properly and a huge 9db 150hz bump at my listening position that I need corrected.
It is more than likely something I am doing wrong but at this stage its not obvious.
any and all help very greatly appreciated.
thanks.
The Sponge
Always Adsorbing even if I think I'm full.
Re: Sonarworks measure problem.
Postby leefeel » Wed May 16, 2018 4:52 am
What OS are you using?
leefeel
Postby The Sponge » Wed May 16, 2018 8:08 pm
Windows 10, Sonarworks have now given me a trial update version of measure 4 to fix some software/driver bugs and that has sorted the problem.
The Sponge
Postby Martin Walker » Thu May 17, 2018 8:07 pm
Hi TheSponge,
Well that IS good news - it's always encouraging when a software developer provides an updated version that solves existing problems, so bravo Sonarworks! :clap:
Postby The Sponge » Fri May 18, 2018 2:41 am
One problem I had was systemwide was changing the sample rate from 44.1 as required for measure to 48 even though I had gone into settings and set 44.1 in both the output and input devices setting. I had to unistall it to proceed.
The Sponge
Users browsing this forum: garrettendi
