new questions re-mastering w/DP-008 ex
Postby GS1 » Wed Jun 20, 2018 1:14 am
Much thanks to everyone who replied to my previous post -
Been studying the manual and wonder if anyone could help me understand-
-offline peak detection
-difference between automatic mastering and normalization...
.(are these the same thing just conducted at different times in the mastering process? i.e.automatic mastering is done instead of or along w/compression and normalization is the final process once EQ/compression is finished...
Having done enough studying online about EQ that I have a good sense of things (much thanks again to Hugh and everyone else who helped me understand the difference between the TASCAM's low/high shelf type and other EQ's)..and begun EQ'ng tracks,I've started a similar process w/compression,reading everything available including articles from SOS....
Wondering if anyone knows what the bandwith used in the multi band compressor on the DP-008ex are in specific...I.e.where do the three bands start/end and if there is crossover....
Given the units' high/low EQ parameters I'm assuming the 3 bands are within the 32hz-18 k range used...
I see that there's some variation from article-article in terms of specific #s for frequency ranges-
I'm thinking the 3 might be-
32hz-250hz LOW
250-4k MID
4-18k HIGH
All replies appreciated....
GS1
