Headphones for Mixing
Re: Headphones for Mixing
Postby Wonks » Fri Oct 19, 2018 3:24 pm
Note that you don't need to turn Sonarworks off if you are using Cubase and put the Sonarworks plugin in the monitor or headphones rack in the Studio section. Only if you've had to put it on the master bus will you need to turn it off when rendering down.
