Recording 'line out' virtually
Page 1 of 1
PostPosted: Tue Oct 09, 2018 1:28 am
by Elephone
Hello. There are some delay effects in adobe audition that I like, and don't appear to be automate-able. I was going to take a line out and record, then play it back in, but I'd much rather capture it virtually.
Is there any way to route or capture the output in realtime without taking a line out, with standalone software like audition? Is there some software similar to streaming software that will capture it? In full quality obviously.
Thanks in advance.
Re: Recording 'line out' virtually
PostPosted: Tue Oct 09, 2018 7:13 am
by ef37a
If you are running Win 7 there should be an option to use the On Board Soundcard usually Realtech or some such moniker.
You might have to do a bit of hacking around in the W7 Sounds menu (quite possible that OBS is turned off. Enable it for the duration) . What you need is to record "Stereo Mix".
Quality? This is all in the digital domain, no converters involved so good as it gets?
If you are running W10 I understand the facility has been removed and you will need some additional software. Someone here will know what.
PostPosted: Tue Oct 09, 2018 12:42 pm
by Mixedup
Voicemeeter Banana might do what you want?
PostPosted: Tue Oct 09, 2018 6:26 pm
by Elephone
Thanks!
