best sequencer for loops?
Postby kcseb » Sun Nov 18, 2018 11:44 am
Hi all
I'm a long-time Cubase user. I record traditionally (i.e. full length multi-tracking) but also like working with loops, building tracks based on layering loops on top of each other and pitch-shifting and tweaking as needed.
I currently use Stylus RMX for this, an old VSTi plugin (mainly aimed at drum users) which can import REX, WAV, loops, etc. However it's a clunky solution and a bit like using a 'sequencer within a sequencer', so not a great workflow.
What other software could I look at that allows you to create tracks based on layering up loops quickly and intuitively?
Thanks!
kcseb
Re: best sequencer for loops?
Postby fatbenelton » Sun Nov 18, 2018 12:36 pm
Not sure what platform you are on but PC only Magix Acid should do the trick. Just updated to Pro 8 after languishing under Sony for years.
https://www.magix.com/gb/music/acid-pro/
It's a full fat sequencer though so may not suit your workflow alongside Cubase.
fatbenelton
Jonny
Postby The Elf » Sun Nov 18, 2018 5:37 pm
I don't have any interest in loops, so it's not something I've made a study of, but I know that Cubase has tools in there to help with tempo-matching, slicing, stretching and stuff like that. It would be worth seeing what can be achieved by Cubase itself before pulling in a plug-in.
Postby Wonks » Sun Nov 18, 2018 8:00 pm
Again, I've never used it, but Ableton is more geared towards loops than Cubase, and it is from the same stable.
Postby Ramirez » Sun Nov 18, 2018 8:58 pm
I use Bitwig Studio a lot. I like it.
Ramirez
Postby desmond » Sun Nov 18, 2018 10:24 pm
Wonks wrote:Again, I've never used it, but Ableton is more geared towards loops than Cubase, and it is from the same stable.
+1
"Live" has a great set of tools for this kind of material, and is a great complement to a more conventional DAW, imo.
desmond
Postby fxsoundscapes » Mon Nov 26, 2018 4:04 pm
hmmm.. I use Cubase but usually i see all the loop people using FL Studio. They say its simpler to use but after working with Cubase for 10 years, i cant figure it out. Use what you know the best! :ugeek:
fxsoundscapes
Users browsing this forum: DGL.
