Radio compression?
Page 1 of 3
Radio compression?
PostPosted: Tue Jan 08, 2019 11:17 am
by Humble Bee
When I hear music on the radio it is always pretty heavily compressed. What kind of compression are we hearing here?
Just wanted to squish a few of my mixes with radio style compression to hear what that sounds like...
Thankful for any insights :thumbup:
Re: Radio compression?
PostPosted: Tue Jan 08, 2019 11:33 am
by Wonks
I'm sure Hugh will be along to say what happens at the BBC, but here's a portion of a post from the PitBull Guitars' recording forum where Marcel, who has worked on radio hardware for most of his life, describes the general setup in Australia.
"In the early days of broadcasting (back when AM radio was King) it was found that over driving transmitters was a very bad thing which apart from adding unwanted distortion to the voice of the DJ also had the problem of making it very difficult for the listener to tune in their often quite basic radio. Other problems included 'splatter' where one radio station could be heard on multiple places on the old school dial. So to alleviate this it was decided and internationally legislated way back in great grandads day that hard audio limiters in the audio chain would be mandatory and ALC (Automatic Leveling Control) would be an recommended option that each station could implement at their discretion.
Fast forward to the '70's and the whole broadcast audio limiting/ALC changed into a race into who could sound the best/loudest. A plethora of new solid state devices that optimised the audio for transmission were devised and implemented. This all came under the thinking that a smaller and cheaper to operate transmitter if modulated correctly could sound as loud as a transmitter 10 times the size and cover as many miles or kilometres as one twice the size, so it was a cheap way of boosting presence on the dial, to sound bigger, better, more awesome all for less money....
FM radio and TV didn't escape the madness. They too have their own versions driven by the desire to sound the best/loudest while staying within the national Federal broadcasting regulations.
So what do they do?. Well essentially the hard limiter by legislation must be there, often in the form of a fast attack and fast release 20:1 compressor with the threshold set at 95% modulation as the last element just before being sent to the transmitter, purely to prevent over modulation. But the ALC part is where it gets interesting. The automatic levelling part is for the most part again is a 20:1 compressor that has a fast attack and very very slow release and a threshold set quite low in the 10 to 30dB below 0VU range used with the intention of averaging all the audio to a predetermined volume. As part of the averaging the audio is broken down into frequency ranges that are also averaged. The number of frequency groups is determined by the type/style of typical program material, but typical breakdowns are usually between 4 and 8 frequency groups. If you think of a 2way or 3way crossover in your typical loud speaker it's a similar type breakup of frequencies being done, one or two bass frequency groups and one or two mid frequencies and one or two treble frequency groups. All the individual frequency groups are ALC'd individually before being recombined into the one signal that is sent to the hard limiter and then the transmitter....
Setting up one of these 'audio processors' is a black art reserved for the station technical engineer under the verbal direction of the station management team. Nobody 'plays' or fiddles with the station audio processor as it does invariably affect how the station sounds to all its listeners.
So if you were ever wondering why your CD or MP3 sounds so vastly different on the radio than from your home stereo, that is why.... The processor does change the 'sound' of the audio passing through it...
If you're interested in seeing a very popular model of these 'audio processors' in operation then follow the link which will take you to a YouTube list of demonstrations.... https://www.youtube.com/results?sear...=orban+optimod
The photos are of the one I had the joy of adjusting just the other day... "
So basically very heavy multi-band compression/limiting followed by another limiter to ensure nothing above a regulated maximum signal level.
Here's a link to the original post. http://www.buildyourownguitar.com.au/forum/showthread.php?t=8762&p=169417&viewfull=1#post169417
PostPosted: Tue Jan 08, 2019 12:31 pm
by Hugh Robjohns
Humble Bee wrote:When I hear music on the radio it is always pretty heavily compressed. What kind of compression are we hearing here?
As Wonk's article intimates, it's usually a form of multiband compression coupled with look-ahead brick wall limiting. There are several different competing manufacturer's of broadcast processors, but Optimod and Innovonics are probably the best known devices.
The number of compression bands employed varies between the different radio broadcasters depending on the kind of 'sound signature' they want to have. Commercial pop music stations tend to have far more elaborate multi-band setups than national classical music radio stations, for example. Some stations also change the compression characteristics they use at different times of day to try and optimise the sound for people driving in their car during at rush hours, say, or listening to a classical concert in the evening.
You're never going to match the sound exactly because each station is different and uses different equipment, but a three or four-band multi-band compressor will be needed, followed by some fiddling to get something sounding similar.
Of course, this kind of broadcast processing is all about peak-normalisation and was both the predecessor (and arguable successor) of the CD loudness wars... but there are international plans to move radio broadcasting away from peak-normalisation and into the loudness-normalised world, where broadcast TV, internet TV and music streaming services are already settling. It's already happened for some DAB stations in some Scandiavian countries, but it's a difficult transition to make so it will take another decade or so I reckon before it's universal.
PostPosted: Tue Jan 08, 2019 2:48 pm
by James Perrett
Take a look at Thimeo Stereo Tool if you want to get some idea of what is involved in broadcast processing
https://www.stereotool.com/
There are a number of presets included for various types of FM processing.
PostPosted: Tue Jan 08, 2019 3:14 pm
by ManFromGlass
So hypothetically some mixes suffer on radio and some might sound improved depending on the station of playback?
PostPosted: Tue Jan 08, 2019 3:24 pm
by desmond
It depends what you mean by "improved"..! ;)
If music crushed to within an inch of it's life sounds "better" to you, then great! Certainly, intelligibility can be improved in noisy environments like a car, as the dynamic range is significantly reduced.
I still have some nostalgic fondness to how the radio sounded back from when I listened to it a lot, but I also remember the first time I had something of mine played on the radio, and was rather depressed as to how it sounded! :protest: :headbang:
PostPosted: Tue Jan 08, 2019 4:54 pm
by Hugh Robjohns
desmond wrote:It depends what you mean by "improved"..! ;):
Quite! I recall enjoying Marc Almond's 'A Lover Spurned' in the car listening to BBC Radio 2 back when I was doing a lot of motorway driving, so I bought the CD Single, only to discover that the CD mix and spectral balance sounded substantially different thanks to the absence of multi-band compression!
PostPosted: Tue Jan 08, 2019 5:03 pm
by Guest
For an electronic part of a concert work I recorded the traffic news from a West Midlands local radio station, to mix in with spoken voice, station announcements and ambient recordings. Because I am outside the area I recorded the live streaming on the internet. The limiting is beyond extreme, it sounded like Acid Mothers Temple on untested narcotics. It sounds as if they recorded the announcer, speeded it up, and then pushed the sound until it clipped - it is unpleasant to listen to.
PostPosted: Tue Jan 08, 2019 5:19 pm
by Mike Stranks
Over the past three years I've done a fair bit of work with a local community radio station. Shortly after I started doing some tech-operator work for them I encountered two issues:
* Presenters asking why the station was quieter than other Internet stations they listened to.
* A huge dynamic range between voice and music.
Thus on the programmes I was responsible for (prerecorded) I used this: http://www.vst4free.com/free_vst.php?id=548 as a matter of course - usually on its 'normal' setting.
Dealt with both issues quite nicely - and it's free!
PostPosted: Tue Jan 08, 2019 5:30 pm
by CS70
Wonks wrote:I'm sure...
Gotta love this forum. I had no idea. Thanks! Wonks for the brilliant explanation!
PostPosted: Tue Jan 08, 2019 7:03 pm
by ManFromGlass
From the music creators perspective once the final mix leaves the studio and or mastering facility it’s all downhill from there. So a very small group of people actually get to hear the mix in its intended glory. That must be depressing for some.
PostPosted: Tue Jan 08, 2019 7:08 pm
by Wonks
Maybe, but there's some compensation when the royalties come pouring in.
Well, back in the times when they used to.
PostPosted: Tue Jan 08, 2019 7:25 pm
by ManFromGlass
So Mr. Wonks - knowing radio compression as intimately as you do, do you compensate in some manor with your mixes?
PostPosted: Tue Jan 08, 2019 7:31 pm
by Wonks
Me? That was a quote from someone else on another forum! I did try to make it clear that it wasn't me.
Now if you want to know all about pressure independent control valves, I'm your man!
PostPosted: Tue Jan 08, 2019 8:29 pm
by Mike Stranks
ManFromGlass wrote:So Mr. Wonks - knowing radio compression as intimately as you do, do you compensate in some manor with your mixes?
If I may speak from personal experience... absolutely not!
When I started location recording for the BBC I used to get it what I felt was 'broadcast ready'. But then when I heard the programme broadcast it sounded dreadful. I'd taken no account of what was a reasonably heavy duty broadcast-processor in the transmission train.
I quickly learnt to go very easy on processing the recording before submitting it for TX. Some gentle EQ if needed, some HPF and the lightest of compression - if any at all. I also discovered that the optimum level for that particular station was -3dB. Anything hotter got the broadcast processor too excited.
As for crafting mixes... you could in theory and I guess I was because all my output destined for broadcast was going to one station. But radio stations all have their own settings for their hardware or software processors and probably different settings for FM and DAB within the same station. Trying to second-guess what might happen to your sound at a multiplicity of radio stations is impossible.
