Trying to make a PIANO VST sound better.
Re: Trying to make a PIANO VST sound better.
Postby ef37a » Thu Jan 31, 2019 2:20 pm
CS70 wrote:
Dr Huge Longjohns wrote:One of the most important things to getting a realistic piano sound is to use a sustain pedal or to write in the sustain patterns in your DAW. If you're not a piano player this might be a complete revelation to you, but using a sustain pedal as pianists do will transform the realism of any plugin, even less expensive ones.
Fascinating! I was thinking of dabbing with some midi piano and I'll definitely keep this in mind.
Not remotely my area but I note all but the very cheapest MIDI controllers have a jack for a sustain pedal.
Postby CS70 » Thu Jan 31, 2019 3:36 pm
Yeah my idea is to actually write the midi (my mouse skills are better than my keyboard's) so the idea of automate the sustain sounds like one these little secrets which can make a lot of difference..
Postby Dr Huge Longjohns » Thu Jan 31, 2019 4:02 pm
Night and day. Hopefully a proper piano player might chip in?
Dr Huge Longjohns
Postby blinddrew » Thu Jan 31, 2019 5:21 pm
Interesting! Noted for future reference. Thanks DHL! :)
Postby Eddy Deegan » Thu Jan 31, 2019 5:46 pm
CS70 wrote:Yeah my idea is to actually write the midi (my mouse skills are better than my keyboard's) so the idea of automate the sustain sounds like one these little secrets which can make a lot of difference..
Dr Huge Longjohns wrote:Night and day. Hopefully a proper piano player might chip in?
I consider myself a proper piano player (for reference, not for promotion here's a piano performance of mine on an 'ok but not great' piano sound recorded live recently: https://soundcloud.com/eddy-deegan/recollection) and having read through the thread a couple things that jump out at me.
Firstly, a low-quality piano sound played well is far preferable than an amazing piano sound played badly. Unless you're showcasing a specific instrument and want to show what it sounds like, on a piano music will sound 'better' when played well.
Secondly, for anything other than really simple music it's going to be extremely hard if not impossible to create a convincing piano part using a MIDI editor.
In order to play 'with feeling', the push and pull against the beat (if indeed there is a beat), the momentary pauses and the anticipated attacks are important. Equally so are the variations in velocity. Within some combination of both of these the result will sound mechanical and lifeless unless it's buried in a mix or used only to add texture to a larger soundscape.
A sustain pedal makes a HUGE difference and I consider it to be a fundamental part of the instrument as opposed to a controller.
Some of my works.
Postby Martin Walker » Thu Jan 31, 2019 6:10 pm
ef37a wrote:Not remotely my area but I note all but the very cheapest MIDI controllers have a jack for a sustain pedal.
And if you're on a really tight budget, bear in mind that an electronic sustain pedal is simply a momentary on/off switch - yes, I've got two elegant piano-like sustain pedals connected to my main keyboards, but the one connected to my 2-octave 'editing' keyboard was originally a footswitch from a dictaphone :headbang:
You can typically buy a similar one in the UK for just £8! 8-)
Postby Eddy Deegan » Thu Jan 31, 2019 6:40 pm
Oops, correction for my previous post in the thread:
Within some combination of both of these ...
I did of course mean
Without some combination of both of these ...
Some of my works.
Postby Eddy Deegan » Thu Jan 31, 2019 6:44 pm
If you'd like some help with creating or playing a piano part, feel free to PM me - I can probably just session it for you and send you the MIDI file and I'm happy to help out a fellow forum member :thumbup:
Some of my works.
Postby CS70 » Thu Jan 31, 2019 6:46 pm
Eddy Deegan wrote:Secondly, for anything other than really simple music it's going to be extremely hard if not impossible to create a convincing piano part using a MIDI editor.
Was afraid you would say that :D :thumbup:
Postby Dr Huge Longjohns » Thu Jan 31, 2019 7:16 pm
Thanks Eddy! :thumbup:
Dr Huge Longjohns
