Noise Cancelling Studio Headphones?
Re: Noise Cancelling Studio Headphones?
Postby Hugh Robjohns » Sun Feb 24, 2019 4:53 pm
Jez Corbett wrote:Can drivers that small really deliver deep bass?
[edit -- Sam got there first!] Yes, but only if the earpieces fit with a good seal in the ear canal, so on generic in-ears / earbuds selecting and fitting the right size of removable grommet to suit your own ears is absolutely critical to the performance -- as is fitting them into the ear correctly. Moulded in-ears should fit perfectly by definition, of course...
Although some in-ears manage to use a 'traditional' moving-coil driver like a miniature headphone system (like the Sennheiser IE800s, for example) the vast majority of ear-buds/in-ears use 'balanced-armature' drivers.
However, it's difficult to make these with a very wide and uniform operating bandwidth, so for high performance applications most manufacturer combine two, three, or even four, balanced-armatures of different sizes in each earpiece optimised to cover different parts of the spectrum -- much like a multi-way speaker system.
But yes, the performance of a good in-ear system well-fitted is just as good as a decent external headphone.
Postby The Elf » Mon Feb 25, 2019 8:24 am
Jez Corbett wrote:I must admit I've never heard a pair of in-ear phones that actually have decent low end performance at all. I've had friends say "oh you need to try these, they have serious bass" and they still sound tinny as hell compared to big cans.
I used to think that until I got them *properly* in my ears - they need to seal fully. I imagine custom moulds would do similar. Until you've heard them this way you haven't truly heard what IEMs can do.
I wouldn't go back now for anything!
Postby Zukan » Mon Feb 25, 2019 9:26 am
Which ones do you have P baby?
Zukan
Postby The Elf » Mon Feb 25, 2019 9:41 am
I have the Sennheiser ew 300 IEM G3. Not top spec, but since I'm only a lowly keysman they do fine.
https://en-uk.sennheiser.com/wireless-microphone-live-monitoring-system-ew-300-iem-g3
I use the supplied buds and I find them OK as long as I jam them *fully* into my ears. I think they're about as far as they can go, then I wiggle them forward a touch and they go in further and nearly disappear into my ear! At that point the bass opens up and they sound absolutely fine. I have to admit I'm a bit concerned that one day I'll lose the rubber seal in there - ugh!
I did consider getting moulds done, and even investing in better buds, but these are actually adequate for my purposes.
Postby Pete Kaine » Mon Feb 25, 2019 10:51 am
Second one for Comply tips here, the difference that getting a proper inner seal makes is key when it comes to isolating in-ears. Running with E80's here and it's a perfectly capable combination for when it comes to blocking out the guys sat around me.
Pete Kaine
Postby ore_terra » Mon Feb 25, 2019 11:01 am
I agree that mixing with sound cancelling (in my case the Quietcomfort 35 II) feels a bit weird, but I'm loving them for tracking and location recording! I find that weirdness a fair price to pay in exchange for the isolation. when recording in the same room than the drums, I find myself getting mic positions and settings quicker, most of all the low end.
I'm using them with Sonarworks.
ore_terra
Postby Jez Corbett » Mon Feb 25, 2019 3:52 pm
So, couple of things I've worked out from this thread:
1. Noise cancelling headphones do weird things to sound, can't really monitor with them (as suspected).
2. In ear phones can deliver proper bass if fitted right.
I'm going to consider option 2, but in the mean time, any good fairly well sealed closed back studio headphones I should consider? I've never really been a fan of in ear, especially not for all day every day, and with not being able to try them out I'm a little hesitant to splash the (client's) cash before I consider all options.
Also I suspect the €1000 Sennheisers might raise eyebrows a little too high.
Jez Corbett
Postby Wonks » Mon Feb 25, 2019 4:04 pm
The €500 Neumanns might be worth considering, but too new for any worthwhile reviews.
Postby Sam Spoons » Mon Feb 25, 2019 4:13 pm
Good old Sennheiser HD25 mk2s are pretty decent, good isolation and reasonable sound quality. They are 'on ear' rather than 'over ear' so, as they need to be fairly tight, some find the uncomfortable. I wear glasses and don't find a problem wearing them for moderate periods of time but definitely a try before you buy.
Postby blinddrew » Mon Feb 25, 2019 4:24 pm
Beyer DT770s with an instance of Sonarworks might do a reasonable job if the fit is good, but I know some folks are less keen.
Postby Jez Corbett » Mon Feb 25, 2019 4:35 pm
blinddrew wrote:Beyer DT770s with an instance of Sonarworks might do a reasonable job if the fit is good, but I know some folks are less keen.
DT770s fit just right for me, should have mentioned they would be my first choice, unless there's anything else worth considering that are more isolating.
Jez Corbett
Postby Hrodulf » Mon Feb 25, 2019 5:00 pm
I'm not too keen on recommending IEM's for critical stuff. Mainly because they're super sensitive to how you put them in and what tips you've chosen. That's the reason why we don't officially support them for Reference 4.
A decent pair of ANC cans like the Bose QC25/35 or Sony WH1000-XM2/3 with calibrations seem like an overall better choice.
Hrodulf
Postby The Elf » Mon Feb 25, 2019 7:56 pm
From my experience with them I wouldn't recommend in-ears for critical listening either. For a stage environment they're fine, but that's where my love of them ends.
Postby blinddrew » Mon Feb 25, 2019 9:14 pm
Depending on your use case, the other thing to bear in mind with in-ears is that they're not the best tool for multiple users... :sick:
I'm hoping to get someone else trained up at work so I'm definitely in the market for over-ears.
Oh well, just have to work with what we have in my case.
#firstworldproblems :)
Postby Wonks » Mon Feb 25, 2019 9:21 pm
Get an Igor so that you can keep the same in-ears and just swap the ears themselves over.
