UA plug in problem in reaper
Postby hooty2 » Mon Mar 04, 2019 3:30 pm
Hi,
any direction on solving this glitch (or...that i've not set things up correctly) would be much welcomed.
e.g. i split a track and add a UA plug in to the newly created item (item properties/fx) (all UA plugins exhibit the unwanted behaviour)
on playback/audition..i hear all glitchy noise and stuttering near the end of the item containing the plug in and into the next item.
when rendered, that noise is not there.
a short example can be here:
https://soundcloud.com/user-463354445/s ... in-problem
part 1 is with the track played back (over a speaker, slight volume difference)
part 2 is the rendered track (sample)
any thoughts please?
cheers
hooty2
