Giving vocals a consistent volume through the mix
Re: Giving vocals a consistent volume through the mix
Postby CS70 » Thu Mar 14, 2019 11:02 pm
Zukan wrote:Definitely a parallel kinda dude I be. Basses, vocals, drums and sometimes the whole mix.
I have this little trick whereby I bandpass the mix into three sections with each section being run off an auxiliary. I then treat the auxes to get the final balance and colour nailed. Works a treat and a really good way to master problematic mixes.
Woah, never thought of that! Great idea to try!
Postby The Elf » Thu Mar 14, 2019 11:27 pm
Somewhere I have a Cubase template that uses clever polarity trickery to negate the phase problems associated with creating a three-band filter split. If anyone is VERY interested I'll try to fish it out, but I will admit I can't recall how I came up with it - it works though!
Postby Hugh Robjohns » Fri Mar 15, 2019 11:47 am
Yes please! :thumbup:
Postby The Elf » Fri Mar 15, 2019 12:38 pm
Hugh Robjohns wrote:Yes please! :thumbup:
Bluff called! :lol:
Here goes:
Postby The Elf » Fri Mar 15, 2019 12:41 pm
It's a few years since I created this, so I'm struggling to recall the details.
Essentially what it does is split the source into low, mid and high bands by use of filters and uses polarity inversion to remove crossover artefacts. It was based on a two-way mult someone showed me, but I gnawed at it until I came up with a three-way technique.
The 'original inversion' channel is simply to prove that no artefacts remain. When un-muted with all faders at unity the output shou;d be null - and it is!
Postby The Elf » Fri Mar 15, 2019 4:56 pm
Have I successfully scared everyone into stupefaction?! :lol:
Postby blinddrew » Fri Mar 15, 2019 6:24 pm
We're cogitating...
Or waiting until we're at a screen where we can zoom in enough on the screen shots to see what's actually going on! :)
Postby The Elf » Fri Mar 22, 2019 3:15 pm
Postby Wonks » Fri Mar 22, 2019 3:20 pm
As clear as Brexit so far.
Postby Wonks » Fri Mar 22, 2019 3:29 pm
Possibly because you've posted two pictures of a low pass filter, when you wanted one low pass, one band pass and one high-pass filter.
Postby Wonks » Fri Mar 22, 2019 3:37 pm
And without being able to see where the outputs of the channels are being sent to (I can see where aux sends are going) it's impossible to work out the full routing path.
Postby The Elf » Fri Mar 22, 2019 3:37 pm
Wonks wrote:Possibly because you've posted two pictures of a low pass filter, when you wanted one low pass, one band pass and one high-pass filter.
Nope - it's correct as shown. It's all about polarity and routing. Take another look!
Postby The Elf » Fri Mar 22, 2019 3:38 pm
Wonks wrote:And without being able to see where the outputs of the channels are being sent to (I can see where aux sends are going) it's impossible to work out the full routing path.
It's all there - top of the channels.
Postby Wonks » Fri Mar 22, 2019 3:41 pm
No, not getting it. And the second photo shows the audio has already come from a high pass filter, so it is effectively a band-pass filter for the mids.
I know you know what you're doing, but it's not as easy to let us know what you are doing.
:thumbup: missed that - all rather small.
