Problem with MIDI mixer and sends in Reaper
Postby Elephone » Wed May 22, 2019 9:21 pm
Hi. I don't know if anyone else has had this problem with Reaper....
I simply want to create the usual aux sends, but be able to control them using a MIDI mixer.
I've got the M-Audio MIDIMIX controller, not great, but still works well generally.
When I create an FX track, and send several tracks to it, I can adjust the send volumes of each track using the mouse as expected.
But I can't seem to assign different MIDIMIX pots to control these track send volumes individually.
I go to the actions list and assign the upper pots to Track #1 send volume, Track #2 send volume, etc, and they are all assigned individual messages.
But I find the MIDIMIX pot I assigned to Track #1's send volume... also controls the send volumes of all the other tracks.
Any advice or workarounds?
I suppose I could try adding simple a volume plugin to each track and route them to the FX track, but I'm not sure if that'd create the same problem.
Elephone
Re: Problem with MIDI mixer and sends in Reaper
Postby blinddrew » Fri May 24, 2019 5:02 pm
Have you tried selecting the sends via the trim menu and using the learn function?
Away from my machine at the moment but hope that makes sense?
