Anything cheaper than iZotope's RX?
Page 1 of 4
PostPosted: Mon Jun 10, 2019 9:59 pm
by TNGator
Hey gang. Im plagued on this song with pops and crackles on various tracks. Not extremely loud but they are there. I tried Audacity and it did nothing. I know iZotope software is really good and i have one or two items of theirs. But even the RX7 elements is like $130. Anyone know of a good software fro removing unwanted pops and such? Thanks y'all.
Re: Anything cheaper than iZotopes RX?
PostPosted: Mon Jun 10, 2019 10:24 pm
by awjoe
Adobe Audition is on a subscription model, so at 20 USD a month it's cheaper than RX depending on how long you plan to use it. And it's great noise reduction software.
PostPosted: Mon Jun 10, 2019 10:43 pm
by Mike Stranks
Before I went over to Izotope I used Magix Audio Cleaning Lab. Not in the same class as Izotope but it is a lot cheaper. For the money I was happy enough with it as long as I didn't let it 'auto' anything, but set the parameters myself.
Hint: two gentle passes is better than one more aggressive one...
PostPosted: Mon Jun 10, 2019 10:44 pm
by James Perrett
You need the standard version of RX to effectively remove pops and crackles as the Elements version doesn't include De-crackle or spectral repair. I also use Adobe Audition (albeit the old Version 3) and find it to often be better at removing pops and crackles from vinyl while still retaining the original sound quality. I also find Audition better at removing single clicks - RX seems to have a habit of affecting audio outside the area that you select.
And as Mike says, multiple gentle passes are always better.
PostPosted: Mon Jun 10, 2019 11:08 pm
by TNGator
Thanks AW, Mike and James. Much obliged. Yes the RX Elements wont be use then by the sounds of it. I'll check out Audition and Magix. It's just this one particular project and i dont want to have to re-record the various problem tracks. I could subscribe for the $20 a month and then cancel when Im done.
PostPosted: Mon Jun 10, 2019 11:19 pm
by TNGator
That Soundforge looks pretty useful and is about $80. A lot cheaper than iZotopes baby.
PostPosted: Tue Jun 11, 2019 12:39 am
by James Perrett
TNGator wrote:That Soundforge looks pretty useful and is about $80. A lot cheaper than iZotopes baby.
I wasn't particularly impressed by any of the Sony or Magix restoration software when I last looked at it but that was many years ago so it may be better now. As you already own some Izotope products it is well worth checking out their special offers as they often have good deals on RX for existing customers.
PostPosted: Tue Jun 11, 2019 7:27 am
by TNGator
I might fire them an email. One of the guys here said that Elements doesnt have the De Click so it wouldnt be much use. I'd have to get the next one up which is RX Standard. And that bad is about 300....ouch.
PostPosted: Tue Jun 11, 2019 7:59 am
by ConcertinaChap
James Perrett wrote:As you already own some Izotope products it is well worth checking out their special offers as they often have good deals on RX for existing customers.
I was about to post similar. They're like a few other companies like UAD - their software is expensive but they quite frequently come up with generous upgrades and offers. Thus I got RX6 Elements originally for 25 quid and worked my way up to RX7 Standard over the next few months in relatively inexpensive steps. The time scale may not help you but if you can wait it's a good strategy.
PostPosted: Tue Jun 11, 2019 8:22 am
by Zukan
Acon Digital might be worth a look. Cheap as chips.
https://acondigital.com/products/restoration-suite/
PostPosted: Tue Jun 11, 2019 9:07 am
by Mike Stranks
.... several versions ago the Magix offering incorporated Spectral Repair under licence from Izotope. Fortuitously I have that version as well as a comparatively recent one... It's a bit glitchy, but does what it's supposed to...
James makes an interesting point with which I concur. Although my experience is limited I've found different packages each have their own strengths and weaknesses. So X may be better at de-clicking, while Y may be better at almost transparent hum removal.
I have several different 'cleaning' packages and mix and match depending on what I need to do.
PostPosted: Tue Jun 11, 2019 9:22 am
by Tim Gillett
TNGator wrote:Hey gang. Im plagued on this song with pops and crackles on various tracks. Not extremely loud but they are there. I tried Audacity and it did nothing. I know iZotope software is really good and i have one or two items of theirs. But even the RX7 elements is like $130. Anyone know of a good software fro removing unwanted pops and such? Thanks y'all.
Really to advise with more certainty we need to hear the "pops and crackles" that you are hearing. There are limits to what's possible without damaging the wanted audio. Any chance of a short sample audio?
Tim
PostPosted: Tue Jun 11, 2019 10:28 am
by Mixedup
TNGator wrote:It's just this one particular project
Use the iZotope demo? I can't recall what the limitations are, but typically you can render results from these things in one way or another.
Or if it really is just the one project, why not invite someone else to do it for you and avoid spending all that time learning to get the best results from whatever tool you purchase? :headbang:
PostPosted: Tue Jun 11, 2019 11:19 am
by ken long
Tim Gillett wrote:Really to advise with more certainty we need to hear the "pops and crackles" that you are hearing. There are limits to what's possible without damaging the wanted audio. Any chance of a short sample audio?
I agree with Tim. Are these pops and clicks convertor sync issues?
Any spectral editor and some elbow grease will work better than a blanket noise removal plugin.
PostPosted: Tue Jun 11, 2019 8:29 pm
by TNGator
Zukan wrote:Acon Digital might be worth a look. Cheap as chips.
Thanks guy..I'll go have a look.
