Hi All
I’m converting an old C90 cassette tape recording from the 1970’s into a CD and cleaning it up in the process. It’s of a family gathering so it’s for my elderly dad, but recorded on a household cassette recorder with the plug in microphones (remember them?!) and the quality of the recording is quite poor.
I’ve had great success so far in removing the tape hiss, hum and general noise with RX7 standard, but there’s some parts where the recording itself is distorted when someone was too loud and too close to the mic.
Has anyone got any suggestions of if and how the distortion can be improved?
Audio restoration advice?
• Page 1 of 1
- Mick C
- Regular
Mick
Re: Audio restoration advice?
If the audio is clipped due to an overloaded input stage then it is worth trying both RX's De-clip and their De-Crackle algorithms but there's not a massive amount that you can do if it is normal tape saturation as this tends to be smoother. I'd probably just play around with the level envelope so that the saturated parts didn't jump out too much.
James Perrett - Moderator
Thanks James
I've tried the both De-Clip and De-Crackle and it didn't really help. I think you're right about the level envelope but just wondered if there was another technique that might give better results. In truth I did think I was clutching at straws..! :headbang:
- Mick C
- Regular
Mick
It's hard to know exactly what to say without hearing what you have there. Any chance of an audio example? Cheers Tim.
- Tim Gillett
- Frequent Poster
No problem, but how do I post it on here? WeTransfer, or is there a more recognised way that works better with this forum?
- Mick C
- Regular
Mick
Most folks just put a private link to SoundCloud
blinddrew - Jedi Poster
I don't have a Sound Cloud account but here's a WeTransfer link. https://we.tl/t-TMes7jcvjI
The track is only 45 seconds long but the saturation is best evident in the first 10 secs or so.
- Mick C
- Regular
Mick
Thanks for the example. Yes it sounds like tape saturation including some bad sibilant overload. I doubt much can be done. At least it's reasonably clear and every word is intelligible. I've heard many official Oral History recorded interviews with State dignitaries. By comparison this is far superior. The use of an external mic rather than a built-in one probably had a lot to do with it. Cheers Tim.
- Tim Gillett
- Frequent Poster
Thanks Tim. I appreciate the feedback
- Mick C
- Regular
Mick
