Abbey Concert Recording Opinions Required
Postby hooty2 » Fri Jul 26, 2019 3:07 pm
Hi all.
Taking a risk here, but, live and learn!
I was recently asked to record a concert at Tewksbury Abbey as part of the Cheltenham music festival. Artistes were Jess Gillam (young musician of the year & Manchester Camerata)
Stress was put on the Archive requirement of the project and I was asked not to get too hifi about it all...but for me..a real opportunity to do my best, with world premier presentations to boot!
I have put up two possible files for submission on Soundcloud. It is track two i am specifically asking about here (schoeps cmc65)
You may like to snippet a listen at the Royer track for comparison?
One: https://soundcloud.com/user-463354445/t ... x7/s-y3R8a
Is made with Royer SF-12 with x2 AKG CK32 (omni) outriggers on discreet stands),
Two: https://soundcloud.com/user-463354445/t ... ed/s-2FfIP
is made with x2 CMC65 in cardioid/70 deg 25cm with CK32 outriggers. A spare CK32 was a last minute placement onto the harpsichord...just in case.
Both stereo rigs were on a bespoke configured bar on a Panamic cathedral stand...a little closer than i would have liked but had to be guided on exact location (H&S)
I have marked the schoeps track in five places, in middle of the songs...
Do you folks who actually know what your'e doing have any opinions on the sound?
The gavin bryers vocal CD playback was requested to be that loud and i had no control over it's level.
mark two (arvo part) was off stage in the lady chapel...i have tried to emulate the spacey effect of this in the hall, but i also put x2 MC930 stereo pair to get some definition for the archive if needed, without it the sound is a bit too vague i think.
the others...concern me in case the sound is too upfront and not enough of the Abbey character is represented?
Any takers for feedback?...if so, be candid.
regards
hooty2
Re: Abbey Concert Recording Opinions Required
Postby hobbyist » Fri Jul 26, 2019 4:40 pm
hooty2 wrote:Hi all.
regards
FWIW I am certainly not a golden eared snob type but I am not totally deaf either:)
Sampled the soundcloud files: Hard to tell on my PC speakers , especially stereo aspect as the speakers are next to each other,
but it sounded good to me.
It was better than most of the stuff I try to listen to on the PC from various forums. And certainly better than utoob which is mostly craplike sound, based on the few times I had to use one of their vids.
For an archive it is definitely excellent IMHO.
Only thing I would suggest is to compute the distance and angle if you are going to use a near coincident set up. I presume you did that when you said bespoke.
Too many will just look up ORTF or DIN and use that distance and angle without consideration of the actual room, source, or mike location.
hobbyist
Postby forumuser840717 » Fri Jul 26, 2019 8:34 pm
hobbyist wrote:Only thing I would suggest is to compute the distance and angle if you are going to use a near coincident set up. I presume you did that when you said bespoke.
Whilst I do agree with your comment about chosing a setup that's appropriate to the circumstances, and considering how the manipulation of spacing and angle can be useful, if you're going to call it ORTF/NOS/DIN/whatever, then you need to use the configuration specified in the description of those setups.
Otherwise you're just using a near-coincident pair. Nothing wrong with that but I get really fed up with people saying things like I used "ORTF with omnis" or "NOS at 70 degrees and 35cm spacing" You might as well say "I used XY but with three spaced omnis". It's simply wrong.
Of course, one reason that there are specific named configurations for these near-coincident pairs is that they've been found to work as described in enough cases for them to be worth noting down and not just so that people can use them as starting places for experimentation. Though that's fine if you know enough about what you're doing to know when and how to bend/break the 'rules'. Just randomly tiddling about with these specs can produce good things but can also be a waste of time and if described as "ORTF but...." can lead to confusion and misleading of people who read the "ORTF" without understandiug that the "but...." means that they're not hearing ORTF. These terms have specific meanings and shouldn't be bandied about to refer to any old random near coincident setup.
forumuser840717
Postby Hugh Robjohns » Fri Jul 26, 2019 9:09 pm
For the benefit of the forum members with less experience and knowledge than your good self, could you explain how they might compute the right distance and angle* for the near-spaced array?
* For the avoidance of confusion I presume you are referring to the array capsule spacing and mutual angle, rather than the distance between mic array/source and stereo recording angle?
Postby hobbyist » Fri Jul 26, 2019 9:20 pm
I would say they do 'work' , but only work best in the exact same room with the exact same mike placement and same size source as the folks who specified those techniques.
Otherwise there is nothing wrong with using near coincident using values you computed for the room, mike placement, and source size.
Sengpiel has many pages that will let you help compute the optimum.
If close enough is good enough then don't worry about it at all. Just stick a pair of mikes there and enjoy what you record.
I dare say a lot of people read a third hand description of ORTF NOS DIN or whatever and took the numbers as gospel.
And too many people are careless with terminology especially those who do not understand where it came from originally or how.
hobbyist
Postby blinddrew » Fri Jul 26, 2019 9:37 pm
hooty2 wrote:Do you folks who actually know what your'e doing have any opinions on the sound?
I definitely don't fall into that category but I can confirm that I'm thoroughly enjoying it. For what it's worth, I don't think you've lost too much of the abbey character - it doesn't leap out at you but it only takes a moment's attention to position yourself there.
Though I must confess I would prefer a smidgeon more of it. ;)
Postby hobbyist » Fri Jul 26, 2019 9:44 pm
First you need to figure out the result you need for the final usage intended. Do you need mono compatibility, widest image, or what.
Then pick levels, timing, or combination approach.
If you are not going to do it by testing, aka trial and error, with measurement, then you can get close to the best spacing/angle, and distance, using the various pages at sengpiel to use Both distance from source and its size along with the space/angle of the mikes.
MIke sensitivity and other factors may also tend to constrain your choices for distance, as may requirements of the client or venue you are at.
http://www.sengpielaudio.com/calculator ... ension.htm
find the angle from the orchestra (source) size and the distance to be used.
then use this which has many mike types and a boatload of parameters to choose
http://www.sengpielaudio.com/HejiaE.htm
put the orchestra angle (distance dependent) from above into these formulae then read out results based on mike type and spacing/angle
repeat with other distances as appropriate
also of interest
http://www.sengpielaudio.com/Fragen08.htm
http://www.sengpielaudio.com/WellknownS ... Angles.pdf
http://www.sengpielaudio.com/calculator ... sAngle.htm
http://www.sengpielaudio.com/calculator ... curves.htm
hobbyist
Postby Aural Reject » Fri Jul 26, 2019 9:47 pm
This is in no way a response directed at the OP...but :headbang:
Aural Reject
Postby Hugh Robjohns » Fri Jul 26, 2019 10:04 pm
hobbyist wrote:... then you can get close to the best spacing/angle, and distance, using the various pages at sengpiel to use Both distance from source and its size along with the space/angle of the mikes.
I'm familiar with how to work out the distance a particular array needs to be from the source given its SRA and the width of the source. And calculating the SRA given the polar patterns, capsule spacing and mutual angle. That's just trigonometry and there are several handy calculators for that -- like the Sengpeil pages you've listed, or that Neumann app I mentioned to you a while back, and others besides...
But none of these calculators are any help in evaluating the acoustic of the venue, and thus the perspective captured by the (calculated) array.
So, just to be clear, are you recommending placing the mic array to achieve good perspective by ear, and then calculate the correct capsule spacing/mutual angle to achieve the desired SRA... In which case, what mic config do you start with? Or are you advocating calculating the appropriate array distance in some way ... In which case how?
I'm aware different enginers have different techniques, so I'm genuinely interested in your particular approach.
Postby hobbyist » Fri Jul 26, 2019 11:58 pm
Usually I am in a relatively small room, not doing full orchestras in a big hall. But even then you may be limited by stage size, or restrictions by the source or venue.
If you are in a large venue then it depends. Where can you put the mikes? Do you have significant options? Then it is up to your ears to try some and see how you like the results. Maybe if I had enough experience in those places then I could tell by ear and just listening to the room , I could tell which technique would be best and where to put it.
I like to do several takes all at once to ensure one will be better.
Mid/side, xy, ABC, and a near coincident as computed.
And like phish did for fans, take an output from their FOH board too.
At least if you compute where the mikes should be relative to the source and their angle for the distance and size of the room you are better able to make the final decision.
The good news is that the bigger the source, often the bigger the room too, so the room is not as big a factor, with cardioids. But you might want to consider some omni ambience mike(s) in the back.
If it is a full orchestra in a smaller recording studio somebody should already have figured out the best miking unless this is a brand new location and you are an early user.
hobbyist
Postby Tim Gillett » Sat Jul 27, 2019 4:07 am
hooty2 wrote:...Do you folks who actually know what your'e doing have any opinions on the sound?
The gavin bryers vocal CD playback was requested to be that loud and i had no control over it's level...
I listened to some of the tracks last night and intended to listen more carefully this morning but cannot now access the tracks on SC. My impression on the Gavin Briers section was that while the orchestra sounded relatively "close" to the mics, the old man sounded muffled and much further away, a strange effect. This in addition to his being sometimes swamped by those instruments.
If it was my project I would just import the relevant CD track(s) of the man's voice, exactly what was played at the venue, time line it up and bring his voice up as much as needed to better balance with the orchestra.
Cheers,
Tim
Tim Gillett
Postby hooty2 » Sat Jul 27, 2019 7:15 am
To all..
A hasty response..
I suddenly realised i may be out of order posting the tracks before checking it's ok to do so.
I took the tracks off SC.
I will add to the general thoughts expressed however at some point.
Thanks and apologies
hooty2
Postby ConcertinaChap » Sat Jul 27, 2019 8:08 am
Tim Gillett wrote:My impression on the Gavin Briers section was that while the orchestra sounded relatively "close" to the mics, the old man sounded muffled and much further away, a strange effect. This in addition to his being sometimes swamped by those instruments.
I didn't hear the originals before they had to be removed but from your description I guess you are referring to Briars' Jesus' Blood Never Failed Me Yet in which the old man's voice is in fact a loop. So hooty2 would have been constrained by how the loop was actually played back, and for all we know that might have not been so well done.
ConcertinaChap
Postby hooty2 » Sat Jul 27, 2019 8:26 am
It was an extended late night relax, looking out at the wild garden that fostered my rising panic that i may have made a 'rights' faux pas by posting the tracks without prior permission.
I skimmed through the above posts looking for any comments on this aspect and I retain a generalised impression of the thoughts expressed regarding mic placements and configurations etc.
I decide here-on to respond with that general impression in mind for the moment.
Firstly a particular apology to Tim, and anyone else, for the time taken and the will to revisit the tracks...that have now gone...maybe the whole thread should be taken away? (MODS?)
More revealing than the result probably, here is my process on the day (& before)
I have recorded before in the Abbey & knew there to be a big reverb.
I had been instructed to keep the set up simple and unobtrusive as possible.
I had been advised that the Abbey staff are on the ball about how things will be (that's me being diplomatic)
I had never done a public & professional gig like this before, and one that was not with the good will and lee-way of my school cohort.
I had contacted Manchester Camerata to know the size and make up of the ensemble. (++to MC who were more than helpful)
I had wanted the chance to use the Royer Stereo mic on such a situation but had concern that i may be positioned too close to the stage area & also that the rear image would be too boomy.
I reckoned that the balance between direct/reverb sound & stand location would not be fully up to me.
The second stereo pair was a plan B.
I worked closely with the Michael Williams graphics (microphone arrays for stereo & multichannel sound recording).
I like the suggested SRA & it's relationship to the stereo reproduction as regards 'crushing' and i felt there may be some lee-way in positioning of the stand in respect to the stage that would be useful over a certain range (hence the 25cm/70deg) & maintain the representation of the instruments over the sound stage (localisation) while also presenting a large space feel
Maybe i got this thinking wrong?
I added the omni outriggers in case the cardioid pair did not capture enough of the Abbey sound...(the room),... & as a second option for capturing the sides if the stand was not optimum or compromised..
All reasonable thoughts for an aspiring amateur? (saying that is riskier than accepting the commission)
so yes, in truth, i have relied upon pre judgements in the hope there would be enough +/- considering all the contributing factors and that i would maybe/likely have little opportunity for refining the set up.
a FOH p.a. was in place too, for the CD playback and the fx'd solo intro (which for other reasons was played sans fx).
For some reason the cd playback of the mans voice did not appear on my recording rig at recording stage and the foh chap couldn't offer that as had hoped.....i think the desk was repatched and the send was lost on the way....
so...i relied upon the stereo mics/outriggers to capture the mans voice.
MC were very clear about the volume the Cd was to be played at and the recording reflects that and the balance between them thru the programme.
I actually made my own loop of the GB track from my own CD and even cleaned up the background somewhat & considered using that in post (much as Tim suggested)...but then considered, it may not be my role or right to do that?
Indeed, we had two people come to the tech desk & ask " why on earth did 'YOU' play the cd like that, we couldn't enjoy the music!"
The Arvo Part off stage was one thing i did attempt to manipulate in post to at least balance the off-stageness and the spacey abbey sound and the fact of listening to it on a recording.....without the added defintion it's a bit too vague ...you could say..."you had to have been there..."
so, in conclusion, i put some thought and hope into what i was doing and sharing all this gives a little insight into the mind of a recording wannabe.
I don't think i made a hash of it and i will be reading the thread carefully now to see how to refine and advance my own process (if MODS allow it to ride?)
& for that opportunity i have to wait until the school xmas concert in Gloucester.
In the event anyone wants private access to the tracks with professional discretion, please PM me for a private link.
i appreciate the thoughts and advice so far offered.
Regards
hooty2
Postby Mike Stranks » Sat Jul 27, 2019 9:13 am
Thanks for the detailed and informative insights into how you went about this recording and all of the issues that impinged on it. Fascinating!
You seem to have coped well with the typical constraints that can be place on one doing a 'live' recording when an audience is present. Often you have to make the best of the constraints regarding 'Mics here and nowhere else; as unobtrusive as possible; no shiny mics; you can't run cables there; no that's not acceptable, you'll have to take some of those mics down' etc etc etc.
You're right to be cautious about making recordings available publically without having sign-off first. Probably the right call to take them down.
As you know, I'm just up the road from you. Always happy to be 'Mr Shifta' for you subject to my availability. :thumbup:
