iZotope Ozone 8 ANNOYING Plugin Issue
Postby marumbra » Tue Aug 27, 2019 8:06 am
I've recently gotten a copy of iZotope Ozone 8.
The only way I can currently open it is via a .exe file, accessing Ozone as a standalone program and NOT as a plugin through my DAW, Ableton Live 9 Standard. :headbang:
There are Youtube videos of people using Ozone 8 as a plugin within their DAWs which is much more convenient.
How can I run Ozone as a plugin through Ableton? :bouncy:
Software:
- Windows 10
- Ableton Live 9 Standard
- iZotope Ozone 8 Advanced
marumbra
Re: iZotope Ozone 8 ANNOYING Plugin Issue
Postby Zukan » Tue Aug 27, 2019 8:40 am
Are you sure Ableton is pointing to the right plugin path?
Zukan
Postby Mike Stranks » Tue Aug 27, 2019 10:05 am
Zukan wrote:Are you sure Ableton is pointing to the right plugin path?
Yup! I've incorporated IZotope software easily into three other bits of software.
As Zuke says, the .dll file is probably sitting in a folder other than that at which Ableton is looking. Find out where all the other Ableton plug-in .dlls are sitting and just drag and drop the IZotope one into that folder.
Restart Ableton and should be job done. If not, there may be a facility in Ableton to prompt it where to look to update its .dll/plug-in library.
HTH
Postby marumbra » Wed Aug 28, 2019 7:33 am
Thank you all for your replies, most notably Zukan and Mike Stranks! :wave:
I repeatedly changed the default Ableton plugin folder to scan for the desired .dll file and moved it into my plugin folder once it was found.
The problem is solved. :clap:
marumbra
Postby Mike Stranks » Wed Aug 28, 2019 10:03 am
Glad it's sorted. :thumbup:
It is sometimes a case of Hunt the Thimble to makes ure all your plug-in DLLs are where you want them to be. :)
Postby Hugh Robjohns » Wed Aug 28, 2019 10:19 am
Most plugin install programs will offer the option to install into a directory other than its default, and it's worth noting where you want to keep your plugin .dlls and directing new installs straight there. Much easier than playing 'hunt the .dll'
Postby SirEnthusiast » Mon Dec 16, 2019 3:27 am
Hi, Im only able to load parts of izotope ozone in my Daw. Like only compressor by itself, only limiter by itself etc. but not able to see whole ozone interface. Im only able to see whole ozone interface when I open standalone version. Could you help me with this? :wtf:
SirEnthusiast
Postby andy cross » Tue Dec 17, 2019 1:00 pm
iZotope plug-ins appear frequently to come in two parts, both of which are required; so, wherever Ozone 8.dll is, you'll also need to have iZOzone8.dll.
The installer will put them together in the same location, but trying then to move them can cause problems.
andy cross
Postby SirEnthusiast » Mon Jan 27, 2020 5:55 pm
Finally, I got it to work. Thank you for your reply. :thumbup:
SirEnthusiast
